    getting uvw coordinates at a certain point ro poly
    7 Posts 0 Posters 757 Views
      On 11/04/2010 at 13:06, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      hi there,
      can anyone give me a hint how i can get the uv coordinates at a certain point or polygon of an object?
      is it GetUVW(...) what i need to use here? if so, how do i know that i need to use for uvwind?
      thanks in advance,
      ello
        On 12/04/2010 at 02:16, xxxxxxxx wrote:
        Please provide more information. What kind of plugin, etc.
          On 12/04/2010 at 03:45, xxxxxxxx wrote:
          Hi Matthias,
          i have a generator plugin which creates clones on another mesh. There i want to pass the uvw coordinates at the point where the clones are generated to the clones itself so i can do other things , for example transformations based on the uvw coordinates
          ello
            On 12/04/2010 at 07:07, xxxxxxxx wrote:
            In this case you have to get the UVW coordinates from the UVW tag and interpolate manually across the surface.
              On 12/04/2010 at 07:22, xxxxxxxx wrote:
              thank you very much. but what can i do if there is no UVW tag??
              ello
                On 12/04/2010 at 07:27, xxxxxxxx wrote:
                Then you have to create the UVs manually. Please check the TexData structure for example code of Cinema's texture projections.
                  On 12/04/2010 at 07:41, xxxxxxxx wrote:
                  thanks again..
                  ello
