    "Flatten Splines"
    Scheduled Pinned Locked Moved Plugin Requests
    4 Posts 0 Posters 1.4k Views
      On 01/04/2010 at 11:44, xxxxxxxx wrote:
      Hello all...my first post here.  The forum looks like a terrific resource.  I'm looking forward to following along.
      The reason I've landed here today is because of my quest to script something that seems so simple, but I can't figure it out on my own.  I'd call my programming knowledge "intermediate".  I suspect it is simple because it is literally one-click on a single spline object.  But, in my current project, I have hundreds of splines I need to "flatten" in the y-axis (i.e., the XZ plane).
      Of course, the way to do this in the GUI is to simply set the spline object's Y SIZE to zero in the coordinate manager and apply.  This essentially averages the Y coordinates for all the spline's points and forces the spline's points to lie within the XZ plane.
      It would be a great time saver for me to be able to select numerous spline objects in the object manager and execute a script to "flatten" them all to the XZ plane.
      What do you guys think?  Maybe I'm missing some obscure function that does this already?
        On 13/12/2010 at 12:01, xxxxxxxx wrote:
        Maybe a bit late, but i wrote a script for you. Maybe you have another case for using it. 😉
        var obj = doc->GetActiveObject();
          if (!obj) {
              TextDialog("Select an object.", DLG_OK);
              return false;
        var i = 1;
        while (obj) {
        obj#ID_BASEOBJECT_SCALE:VECTOR_Y = 0;
          println(obj->GetName() + " is flat.");
        obj = obj->GetNext();
              if (!obj) {
                  TextDialog((tostring(i) + " Object/s flattened."), DLG_OK);
                  return false;
          i++;
        Greets, nux
          On 21/12/2010 at 05:01, xxxxxxxx wrote:
          Thank you, nux.  Works great.
            On 01/07/2011 at 13:37, xxxxxxxx wrote:
            hey, this is not a code related solution, but using the melt deferrer, settings its strength to zero, and moving to the top of your splines should flatten them in the local Y direction of your deformer. obviously not a coded solution, but still very useful nonetheless.
