    Dialog in script - Bitmap/ButtonBitmap possible?
    8 Posts 0 Posters 650 Views
      On 29/03/2010 at 06:34, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      1)
      I have a script that makes a dialog,
      AddStaticText(0,BFH_SCALEFIT,0,0,"Set name:",0);
      AddEditText(0,BFH_CENTER,400,11);
      etc...
      Its posible to add a bitmap (a logo) or a bitmapbutton ? in the script an as easy way as that ?
      Another question (not related to previus topic) :
      Lets say a dialog have a add and remove button to remove or add items in a combobox or list, is that posible? and it automatically updates de list of items or we have to reload the dialog or something?...
        On 29/03/2010 at 12:06, xxxxxxxx wrote:
        As far as I know, there's no direct possibility to add a bitmap to a GeUserDialog in Coffee. But you could use the member function AddUserArea() to add a GeUserArea. The GeUserArea class offers the member function DrawBitmap(), which should do what you want.
        Jack
          On 29/03/2010 at 16:16, xxxxxxxx wrote:
          Any example please?
            On 30/03/2010 at 01:09, xxxxxxxx wrote:
            Sorry, I code in C++.
            No Coffee examples from me 😉
            Anyone else?
            Jack
              On 30/03/2010 at 08:38, xxxxxxxx wrote:
              Sorry if this question is too silly but:
              Is not posible to put c++ code inside a coffe script?
                On 30/03/2010 at 10:35, xxxxxxxx wrote:
                Of course not. Otherwise it would be called a C++ script.
                Frank
                  On 30/03/2010 at 14:02, xxxxxxxx wrote:
                  or maybe a Zoffee script.. 😄 sorry, couldn´t resist.
                  For examples, search the forum. You will have enough information and example code to create a user area.
                  Generally you should first have a look at basic programming operations in a procedural or object oriented language. It will save you time and head aches.
                    On 31/03/2010 at 05:12, xxxxxxxx wrote:
                    Yes, bitmaps or bitmap buttons are realized through user areas in dialogs.
                    Here is a simple example showing the basic use of user areas. It's just a pure red bitmap but you can use the BaseBitmap loading methods to load a custom bitmap.
                    class MyUserArea : GeUserArea
                          MyUserArea(id,dialog);
                          Init();
                          GetUserWidth();
                          GetUserHeight();
                          Draw(x1,y1,x2,y2);
                      private:
                          var bmp;
                    MyUserArea::MyUserArea(id,dialog)
                      super(id,dialog);
                    MyUserArea::Init()
                      var x = GetUserWidth();
                      var y = GetUserHeight();
                      bmp = new(BaseBitmap,x,y);
                      bmp->SetPen(vector(1.0,0.0,0.0));
                      bmp->DrawRect(0,0,x-1,y-1);
                    MyUserArea::GetUserWidth()
                      return 200;
                    MyUserArea::GetUserHeight()
                      return 200;
                    MyUserArea::Draw(x1,y1,x2,y2)
                      OffScreenOn();
                      SetClippingRegion(x1,y1,x2,y2);
                      DrawBitmap(bmp,0,0,199,199,x1,y1,x2,y2,BMP_NORMAL);
                    class MyDialog : GeModalDialog
                          MyDialog();
                          CreateLayout();
                      private:
                          var ua;
                    MyDialog::MyDialog()
                      super();
                    MyDialog::CreateLayout()
                      SetTitle("My Dialog");
                      AddUserArea(5000,BFH_FIT|BFH_FIT,0,0);
                      ua = new(MyUserArea,5000,this);
                      return;
                    main(doc,op)
                      var d = new(MyDialog);
                      d->Open(-1, -1);
                    Please check the COFFEE documentation for explainations of the classes.
