    Dialog Disables Cinema until is closed
    4 Posts 0 Posters 368 Views
      On 17/03/2010 at 01:25, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Its posible to create a dialog (in coffee is posible?) that can stay like any other cinema window so we can keep using cinema having that window floating there ? ... all dialogs i saw in scripts examples they disable all until u close the dialog, so u can't keep using cinema while the dialog is opened 😞
        On 17/03/2010 at 06:20, xxxxxxxx wrote:
        Yes, this is possible. Non-modal dialogs are created with the GeDialog class.
        Here is an example of a simple test dialog plugin.
        var PLUGINID = 1000158;
        enum
          GADGET_BUTTON = 5000,
          _dummy
        // definition of my dialog class
        class MyDialog : GeDialog
              MyDialog();
              CreateLayout();
              Command(id,msg);
        MyDialog::MyDialog()
          super(PLUGINID);
        MyDialog::CreateLayout()
          SetTitle("My Dialog");
          AddGroupBeginV(0,BFH_SCALEFIT,1,"",0);
              AddGroupBorderSpace(4,4,4,4);
              AddStaticText(0,BFH_FIT,0,0,"just some random text",0);
              AddButton(GADGET_BUTTON,BFH_FIT,0,0,"click me");
          AddGroupEnd();
        MyDialog::Command(id,msg)
          switch (id)
              case GADGET_BUTTON:
                  //button clicked, do something
                  break;
        class MyMenuPlugin : MenuPlugin
              MyMenuPlugin();
              GetID();
              GetName();
              GetHelp();
              Execute(doc);
              RestoreLayout(secret);
        MyMenuPlugin::MyMenuPlugin()
          super();
        MyMenuPlugin::GetID()
          return PLUGINID;
        MyMenuPlugin::GetName()
          return "Modal Dialog";
        MyMenuPlugin::GetHelp()
          return "Demonstrates a modal dialog";
        var d;
        MyMenuPlugin::Execute(doc)
          d->Open(TRUE,-1,-1);
        MyMenuPlugin::RestoreLayout(secret)
          if (!d) d = new(MyDialog);
          d->RestoreLayout(secret);
          d = new(MyDialog);
          Register(MyMenuPlugin);
          On 17/03/2010 at 07:08, xxxxxxxx wrote:
          I love you.  Just one last question about it:
          How can i test this? I know it works making a .cof... but what if i want to test it inside script manager? instead of making a "plugin". So i can change parameter and test them without having to close and open cinema again each time (!?)  😞
            On 17/03/2010 at 07:41, xxxxxxxx wrote:
            It's not possible from within a script. You have to create a plugin.
