    Coffee for Render Effects
    2 Posts 0 Posters 283 Views
      On 16/03/2010 at 08:55, xxxxxxxx wrote:
      Cinema 4D Version:   11+
      Platform:      Mac OSX  ;
      I can't seem to track down how to control the render settings that are now located under "Effect..."
      I can toggle and change the "Options" etc. with renderdata() - but can't find a way to get to these sub items - for example to turn Global Illumination on.
      Should be easy - any help?
      ed
        On 19/03/2010 at 06:27, xxxxxxxx wrote:
        If you have obtained access to the videopost object you can enable/disable the videopost effect with the BIT_VPDISABLED bit. See screenshot below for an example.
        Problem is that you have no direct access through COFFEE.
