    Polygon Plane
    8 Posts 0 Posters 792 Views
      On 06/03/2010 at 20:13, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hey everyone,
      Could anyone tell me the process involved in creating a polygon plane object from scratch?  Or point toward something that can guide me through this process.
      ~Shawn
        On 08/03/2010 at 09:41, xxxxxxxx wrote:
        Anyone have any info about this.  I want to know how to create a plane from scratch.  Not creating a plane primitive, but creating a polygon object and adjusting its points and polygons to create a plane.  Is there something that could point me in the right direction.  I checked out the rounded tube sample in the SDK but I do not see where the geometry is created.
        ~Shawn
          On 08/03/2010 at 12:22, xxxxxxxx wrote:
          Hi, this little example will create a quad with the given coordinates:
          BaseObject *drawPlane::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
               PolygonObject *obj = NULL;
               Vector *padr=NULL;
               CPolygon *vadr=NULL;
               obj = PolygonObject::Alloc(4,1);
               if (!obj) goto Error;
               padr=obj->GetPointW();
               vadr=obj->GetPolygonW();
               padr[0] = Vector(-100,0,-100);
               padr[1] = Vector(-100,0,100);
               padr[2] = Vector(100,0,100);
               padr[3] = Vector(100,0,-100);
               vadr[0] = CPolygon(0,1,2,3);
               return obj;
          Error:
               return NULL;
          hope it helps..
          ello
            On 08/03/2010 at 12:33, xxxxxxxx wrote:
            Great, thanks ello.    I want to be able to control the number of polys on the plane so I would do this by creating more polys like this?
            Thanks again.
            ~Shawn
              On 08/03/2010 at 13:29, xxxxxxxx wrote:
              yes, you just need to allocate the PolygonObject corresponding to that number, or you adjust it later on with ResizeObject(LONG pcnt, LONG vcnt)
              ello
                On 08/03/2010 at 15:18, xxxxxxxx wrote:
                Hi ello,   I copied and pasted your code in to my object plugin just to see how it works and I get nothing.  No polygon is created.  Any thoughts as yo why this is?
                ~Shawn
                  On 08/03/2010 at 23:15, xxxxxxxx wrote:
                  hm. it worked at home. i'll give it another try here at work when i have a break...
                    On 08/03/2010 at 23:33, xxxxxxxx wrote:
                    ok, it works here, too.
                    here is my whole code:
                    #define pluginID 1000001
                    #include "c4d.h"
                    #include "c4d_symbols.h"
                    #include "customgui_description.h"
                    #define pluginName "testObj"
                    class testObj : public ObjectData
                         INSTANCEOF(testObj,ObjectData);
                         virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                         virtual Bool Message(GeListNode *node, LONG type, void *t_data);
                         static NodeData *Alloc(void) { return gNew testObj; }
                    Bool testObj::Init(GeListNode *node)
                         BaseObject          *op          = (BaseObject* )node;
                         BaseContainer *data = op->GetDataInstance();
                    Bool testObj::Message(GeListNode *node, LONG type, void *t_data)
                         if (type==MSG_DESCRIPTION_VALIDATE)
                              BaseContainer *data = ((BaseObject* )node)->GetDataInstance();
                    BaseObject *testObj::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                         Vector *padr=NULL;
                         return obj;
                    Error:
                         return NULL;
                    Bool Register_testObj(void)
                         return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,testObj::Alloc,"OtestObj","testObj.tif",0);
                    hope it works for you..
