    problem with arranging values of an array
    19 Posts 0 Posters 2.4k Views
      On 09/03/2010 at 06:35, xxxxxxxx wrote:
      Well, if you want to do it with a dynamic array, how about an array of dynamic arrays, something like
       GeDynamicArray<GeDynamicArray<Vector>>tposarr;
      then with
      tposarr _[i][j]
      you should be able to address spline i's element no j.  _
      _
      Whereas I would probably just create an array of pointers to splines, add alle the points to the splines, and then add the splines to the scene. By using pointers, you don't have to worry about handing ownership of the splines over to cinema 4d when adding them to the scene.
      _
        On 09/03/2010 at 07:10, xxxxxxxx wrote:
        thank you for pointing that one 🙂 one question remains for me. how do i use push with this? as i did it up to now, using push increased the count of the one-dimensonal array, but what will happen now?
          On 09/03/2010 at 08:34, xxxxxxxx wrote:
          I don't have my Compiler handy right now, so I might be a bit off, but when saying
          tposarr[i]
          what you are dealing with is a the array i, and you should be able to deal with it as though it were a normal array.
          Thus,
          tposarr[i].Push(..)
          should work.
          Also, when working on a new particle, you might need to do something like a
          tposarr.push(new GeDynamicArray<Vector>)
          to append a new array to your array of arrays 🙂
          But bear in mind the following: If a particle's life is only starting in frame 100, then the spline will (with your above code) have the value of frame 100 at position 0, frame 101 at position 1 etc., so whatever you want to do with the splines will not preserve the time. If you want for example to have an object follow the spline, you might need to keep book about each particle's lifespan.
          So, depending on what you want to do, it might be a more interesting alternative to look at animation tracks instead of splines. Depends on your mission 🙂
            On 09/03/2010 at 11:22, xxxxxxxx wrote:
            the mission is to create a trail (spline) for each particle.
            trying to push a new GeDynamicArray<Vector> gives me an error message:
            c4dplugin_test\plugins est\source\etracer.cpp(130) : error C2275: 'GeDynamicArray<TYPE>': Ungültige Verwendung dieses Typs als Ausdruck
                    with
                        TYPE=Vector
            maybe this whole approach wrong? but how else would such stuff work?
              On 09/03/2010 at 13:44, xxxxxxxx wrote:
              Well, if you just want the trail, without regards to thetimeline, then this should do it, even though it's probably not the most efficient algorithm, depending on how many particles you want to deal with.
              As I mentioned I don't have my compiler at hand at the moment, so perhaps someone could check this. I think it should be something like
              tposarr.push(new GeDynamicArray<Vector>())
              (I'd say the ()'s should do it)
                On 09/03/2010 at 22:57, xxxxxxxx wrote:
                Hm, no sorry, the approach with
                new
                was wrong since we're not talking pointers here. But I just saw the GeAutoDynamicArray. It will automatically create new entries on the fly as needed.
                Thus, you could use
                GeAutoDynamicArray<GeDynamicArray<Vector>> tposarr
                Then you don't need the
                tposarr.push(..)
                at all.
                  On 10/03/2010 at 00:08, xxxxxxxx wrote:
                  thank for pointing out GeAutoDynamicArray.. can you show me how to put a vector into it?
                  using
                  tposarr[i][j] = particle->off;
                  results in a bunch of errors so i think this is the wrong method..
                  thank you very much for your help
                    On 10/03/2010 at 01:04, xxxxxxxx wrote:
                    You just do
                    tposarr[i].Push(particle->off);
                    Only the Array containing the Arrays needs to be GeAutoDynamicArray, the Arrays it carries are still of type GeDynamicArray, since there may be "holes" in it (for example if a particle doesn't start in frame 0, but only in frame 100.
                    Example: Particle 100 starts it's lifetime at frame 200.
                    If you'd use GeAutoDynamicArray, you would end up with
                    tposarr[100][200] containing the first coordinate, but tposarr[100][0] up to tposarr[100][199] would all be zeroes, which you don't want.
                    By using the above method, tposarr[100][0] would contain the first position of the particle (at frame 200), tposarr[100][1] the second position at frame 201, ...
                    I suppose that's what you want.
                      On 10/03/2010 at 01:56, xxxxxxxx wrote:
                      hm, still the same error..
                      1>c4d_plugin\resource\_api\ge_dynamicarray.h(470) : error C2440: '=': 'Vector *const *' kann nicht in 'GeDynamicArray<TYPE> *' konvertiert werden
                      1>        with
                      1>        [
                      1>            TYPE=Vector
                      1>        ]
                      1>        Die Typen, auf die verwiesen wird, sind nicht verknüpft; die Konvertierung erfordert einen reinterpret_cast-Operator oder eine Typumwandlung im C- oder Funktionsformat.
                      1>        c4d_plugin\resource\_api\ge_dynamicarray.h(449) : Bei der Kompilierung der Klassen-template der Bool GeDynamicArray<TYPE>::ReScope(VLONG)-Memberfunktion
                      1>        with
                      1>        [
                      1>            TYPE=GeDynamicArray<Vector>
                      1>        ]
                      1>        c4d_plugin\resource\_api\ge_dynamicarray.h(986) : Siehe Verweis auf die Instanziierung der gerade kompilierten Klassen-template "GeDynamicArray<TYPE>".
                      1>        with
                      1>        [
                      1>        ]
                      1>        c4d_plugin\plugins est\source estobj.cpp(15) : Siehe Verweis auf die Instanziierung der gerade kompilierten Klassen-template "GeAutoDynamicArray<TYPE>".
                      1>        with
                      1>        [
                      1>        ]
                      what does this mean??
                        On 10/03/2010 at 02:35, xxxxxxxx wrote:
                        Please send the exact code from your testobj.cpp, line 15 (& neccessary declarations).
                         Can it be that you did
                        tposarr.push(..)
                        instead of
                        tposarr[i].push(..)
                        Because he complains that he got a vector where he expects a GeDynamicArray...
                          On 10/03/2010 at 03:41, xxxxxxxx wrote:
                          line15:
                          GeAutoDynamicArray<GeDynamicArray<Vector>> tposarr;
                          error comes only when i try this:
                          tposarr[frameNum].Push(source->GetParticleR(pt,i)->off);
                            On 16/03/2010 at 10:03, xxxxxxxx wrote:
                            Ok, I get the same errors with 11.5 SDK.
                            It comes grom GeAutoDynamicArray's ReScope.
                            It also comes when I substitute GeAutoDynamicArray with GeDynamicArray and use a manual ReSize() before trying to access an element.
                            Seems like a Ge(Auto)DynamicArray doesn't like to resize itself when it carries other Ge(Auto)DynamicArrays.
                            @Matthias , do you see this as an error in the SDK?
                            Or can you recommend an alternative?
                            I myself would go STL or a manually administrated Array of pointers to GeDynamicArrays, but perhaps you can recommend ello something that requires less manual handling?
                            Here's a minimal code snippet to reproduce the compiler errors:
                              Vector vec;
                              tposarr[0].Push(vec);
                            Mike
