    Assign Xbitmap
    2 Posts 0 Posters 258 Views
      On 26/02/2010 at 11:43, xxxxxxxx wrote:
      Cinema 4D Version:   10
      I am trying to put graphic-file into  color channel of a material. I tried to recover coffee code from c++ code. But it doesnt work.
      //get first material
      var mat = GetActiveDocument()->GetFirstMaterial();
      //get data container
      var con = mat->GetMainData();
      //create new shader
      var shader = AllocShader(Xbitmap);
      //configure shader
      var f = new(Filename);
      f->SetFullString("c:\\	est.bmp");
      shader#BITMAPSHADER_FILENAME = f;
      shader#BITMAPSHADER_INTERPOLATION = BITMAPSHADER_INTERPOLATION_NONE;
      shader->Message(MSG_UPDATE);
      //add shader to container
      println(con->SetData(MATERIAL_COLOR_SHADER, shader), true);
      //return container to material
      mat->SetMainData(con);
      //update material
      mat->Message(MSG_UPDATE);
      mat->Update();
      //super update
      EventAdd();
      I am glad to every hint I may get
      Greetings
      Jimbo
        On 27/02/2010 at 02:52, xxxxxxxx wrote:
        I think I found the answer myself
        " Note: At the moment there's no way to insert an allocated shader into a material with C.O.F.F.E.E.."
        See BaseShader at C.O.F.F.E.E. SDK R9.1
