    Polygon Position
    47 Posts 0 Posters 41.9k Views
      On 15/03/2010 at 13:17, xxxxxxxx wrote:
      no, i am just using clone->SetRot(normal);
      is this wrong??
        On 15/03/2010 at 13:41, xxxxxxxx wrote:
        I'm pretty sure that if you are trying to rotate objects based on a polygon then you will need to create a rotation matrix for that polygon and then make the matrix of the object you want to rotate equal to the rotation matrix.   That's how I understand it.
          On 15/03/2010 at 13:51, xxxxxxxx wrote:
          well, what is so strange is that it works for spheres, but not for terrain objects:
          http://tempfiles.earthcontrol.de/nm02.jpg
            On 15/03/2010 at 14:20, xxxxxxxx wrote:
            Here's how I am doing it.
            								//ROTATION MATRIX
            								//GetPoints
            								Vector c = polyLocation; //midpoint
            								Vector p = points[lngA]; //polygon point
            								Vector n = CalcFaceNormal(points, selectedPoly[lngI]); //normal
            								Vector scale = Vector(Len(opMatrix.v1), Len(opMatrix.v2), Len(opMatrix.v3)); //Get Scale
            								//Contruct Matrix
            								Matrix rotMatrix;
            								rotMatrix.off = p; //The base of the matrix
            								rotMatrix.v1 = !((p - c)%n); //X axis points toward the second point
            								rotMatrix.v2 = !(rotMatrix.v1 % n);//Y Axis is perpendicular to the X axis
            								rotMatrix.v3 = !(n); //Z Axis is along the normal
            								rotMatrix.v1 = !(rotMatrix.v1 * scale.x);
            								rotMatrix.v2 = !(rotMatrix.v2 * scale.y);
            								rotMatrix.v3 = !(rotMatrix.v3 * scale.z);
            								//place the first object within the rotation matrix
            								firstSelection->SetMg(rotMatrix);
            								firstSelection->SetPos((opMatrix * polyLocation));// + firstSelection->GetRad().x);
            This is working quite well now..    creating a rotation matrix gives me the exact rotation of that specific polygon.
            Hope this helps you.
            ~Shawn
              On 15/03/2010 at 14:34, xxxxxxxx wrote:
              thank you so much! now after incorporating the CalcFaceNormal like you did, everything works fine.
              Ello
                On 15/03/2010 at 14:59, xxxxxxxx wrote:
                Great.  I'm glad it worked for you.   I have got it now so everything is working 100% for me too....   Good day for us both!  🙂
                ~Shawn
                  On 15/03/2010 at 17:49, xxxxxxxx wrote:
                  okay .. 100% might have been a bit over zealous.    I've got rotations working properly, but now I am having an issue with position.
                  I use
                  to set where the object will sit on the polygon (the center).
                  however,  I get this...
                  I want for it to look like this...
                  You can see in the second image that the smaller cube is sitting so that the face is right against the polygon of the larger cube.   THis is the result I am looking for.
                  I have tried adding the radius of the smaller cube to the position of the smaller cube but this only works correctly if the object is a cube,  otherwise I get some funky results.
                  Is there a better way to get the postition of the cube to rest polygon to polygon.   For example,  could I temporarily change the axis of the smaller cube so that when I change the position of the smaller cube, the axis is at the outer edge,  and then after I have changed the postiiton, change the axis back..   Is this possible?
                  How would I change the axis of a polygon object?  I have looked at SetModelingAxis() but am not sure how I would use it...
                  Any help would be greatly appreciated.
                  Thanks a lot.
                  ~Shawn
                    On 16/03/2010 at 01:01, xxxxxxxx wrote:
                    I don't know for sure how the tool is supposed to work. Can you post a screenshot of a different example with a more complex geometry?
                      On 16/03/2010 at 02:47, xxxxxxxx wrote:
                      Thanks Matthias,
                      Here are some screen shots of the whole process..  Hopefully this makes what I am doing a little clearer.  🙂
                      The reason I get only half of the cube being visible is that SetPos() is putting the cube in the position of the center of the polygon.  However,  the position of the cube is based on the axis of the cube which is in the center of the cube.
                      I would like to move the axis of the cube to the center of one of the polygons on teh cube so that this polygon is then set on the polygon of the 2nd object instead of the center of the cube.
                      So after all of that....    I really just need to know how to move the axis of the cube from the center of the cube to the center of one of the polygons of the cube.
                      LOL
                      Thanks in advance.    🙂
                      ~Shawn
                        On 17/03/2010 at 01:11, xxxxxxxx wrote:
                        I assume you have created a rotation matrix for the cube's selected polygon. Translate this matrix into global space. Translate the object's matrix (axis) into global space. Translate the new global object's matrix into the polygon's rotation matrix local space. Now offset the the object's matrix by the difference of the original rotation and object matrix offsets.
                          On 17/03/2010 at 17:18, xxxxxxxx wrote:
                          To translate the rotation Matrix of the cube's polygon to global space, I will need to multiply that by the cube's local matrix?
                          ~Shawn
                            Yes I a have.   this is name rotMatrix1
                            Is this the right way yo do this?
                            Matrix globalSelPoly = rotMatrix1 * firstSelection->GetMl();
                            Like this?    (firstSelection is the object that represents the first object selected.)
                            Matrix firstObjGlobal = firstSelection->GetMg();
                            I'm not sure how to do this.   🙂  Would you mind giving an example?
                            I assume that would look something like this?
                            objMatrix.off = rotMAtrix.off - objMatrix.off
                            ~Shawn
                              On 22/03/2010 at 07:18, xxxxxxxx wrote:
                              Got it.  Thanks for everyone's help with this.  Finally worked it out.  HAHA
                              ~Shawn
