    Polygon Position
    47 Posts 0 Posters 41.9k Views
      On 22/02/2010 at 17:28, xxxxxxxx wrote:
      or better yet,   how would I align my first object to the normal of the polygon that is selected?
      ~Shawn
        On 23/02/2010 at 02:38, xxxxxxxx wrote:
        What you want to do is not clearly defined. Basically you have to create a rotation matrix for the polygon. For this you need at least two vectors. One is the normal, the other one has to be defined by you. For instance you could choose the vector pointing from the polygon's midpoint to its first vertex. Or you choose a global vector.
          On 23/02/2010 at 02:54, xxxxxxxx wrote:
          I want to move one object and have it sit on the polygon of another object and have it rotate to the normal of that polygon so that the object is sitting flush with that polygon.   SO I will need the center between all of the points of that polygon (which I have) and a point in space that points directly outward from that polygon?  There is no function in the sdk that provides the normal of a polygon?
          so the vector from the center to the first point would create a plane upon which I could determine rotation?
          how would I get that?
          Here's how I determine the center of the polygon
                                    //Caclulate the polygon position.
                                    if (selectedPoly[lngI].c == selectedPoly[lngI].d)
                                        polyLocation = (points[lngA] + points[lngB] + points[lngC]) / 3; //Polygon is a Triangle
                                    else
                                        polyLocation = (points[lngA] + points[lngB] + points[lngC] + points[lngD]) / 4; //Polygon is not a Triangle
          how would I set up the rotation matrix with this info if points[lngA]  is the first point of the polygon?
          ~SHawn
            On 23/02/2010 at 15:44, xxxxxxxx wrote:
            Okay so I want to set up a rotation matrix for the selected polygon.  do I do this by mulitplying the vector of one point by the vector of a second point in the polygon?
            ~Shawn
              On 23/02/2010 at 15:49, xxxxxxxx wrote:
              Here's what I have so far......
              C4DObjectList * objList = C4DObjectList::Alloc();
                if (!objList) return FALSE;
                //DECLARATIONS & DEFINITIONS
                if (!doc) return FALSE;
                BaseObject *op = doc->GetActiveObject();
                if(!op) return TRUE;
                PolygonObject *objPoly = ToPoly(op);
                if (!objPoly) return FALSE;
                BaseSelect *bsPoly = objPoly->GetPolygonS();
                BaseSelect *bsPoint = objPoly->GetPointS();
                BaseSelect *bsEdge = objPoly->GetEdgeS();
                Real dx, dy, len = data.GetReal(1, 0.0);
                BaseContainer device;
                Real mousex = msg.GetLong(BFM_INPUT_X);
                Real mousey = msg.GetLong(BFM_INPUT_Y);
                win->MouseDragStart(KEY_MLEFT, mousex, mousey, MOUSEDRAG_NOMOVE);
                LONG lngRad = 1;  //MAXIMUM SELECTION RADIUS
                LONG lngEditorMode = doc->GetMode();
                AutoAlloc<ViewportSelect> vps;
                if(!vps) return FALSE;
                LONG left, top, right, bottom, width, height;
                bd->GetFrame(&left, &top, &right, &bottom);
                width = right - left + 1;
                height = bottom - top + 1;
                if(!vps->Init(width, height, bd, op, doc->GetMode(), TRUE, VIEWPORT_IGNORE_HIDDEN_SEL)) return FALSE;
                LONG lngX = mousex;
                LONG lngY = mousey;
                //DRAW CIRCLE TO SHOW HOTSPOT
                vps->SetBrushRadius(data.GetLong(SELECTION_RADIUS)); //SET BRUSH RADIUS
                while (win->MouseDrag(&dx, &dy, &device) == MOUSEDRAG_CONTINUE)
                      if (dx == 0 && dy == 0)
                      continue;
                      lngX += dx;
                      lngY += dy;
                      DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION);
                      vps->ShowHotspot(win, lngX, lngY);
                //SELECT THE POLYGON THAT IS CLICKED
                BaseContainer state;
                LONG lngKey = state.GetLong(BFM_INPUT_QUALIFIER);
                ViewportPixel *vpPoly = vps->GetNearestPolygon(op,lngX,lngY,lngRad);
                ViewportPixel *vpPoint = vps->GetNearestPoint(op,lngX,lngY,lngRad);
                ViewportPixel *vpEdge = vps->GetNearestEdge(op,lngX,lngY,lngRad);
                Bool shiftDown = GetInputEvent(BFM_INPUT_KEYBOARD, state);
                LONG lngPolygonCount = objPoly->GetPolygonCount();
                LONG lngPointCount = objPoly->GetPointCount();
                const CPolygon * selectedPoly = objPoly->GetPolygonR();
                const Vector * points = objPoly->GetPointR();
                LONG lngI;
                Matrix opMatrix  = op->GetMg();
                switch (lngEditorMode)
                    //POLYGONS MODE
                    case Mpolygons:
                        if(vpPoly)
                            //FIRST SELECTION
                            if (secondSelection == FALSE)
                                bsPoly->DeselectAll();
                                bsPoly->Select(vpPoly->i);
                                firstSelection = vpPoly->op;
                                secondSelection = TRUE;
                            //SECOND SELECTION
                            else if (secondSelection == TRUE)
                                for (lngI=0; lngI < lngPolygonCount; lngI++)
                                    if (bsPoly->IsSelected(lngI))
                                        lngA = selectedPoly[lngI].a;
                                        lngB = selectedPoly[lngI].b;
                                        lngC = selectedPoly[lngI].c;
                                        lngD = selectedPoly[lngI].d;
                                        else
                                        //Align 1st Selection to the polygon of 2nd Selection (X AXIS)
                                        if (polyLocation.x > 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation + Vector(firstSelection->GetRad().x,0,0));
                                            firstSelection->SetRot(CalcFaceNormal(points,selectedPoly[lngI]) * opMatrix);
                                        if (polyLocation.x < 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation - Vector(firstSelection->GetRad().x,0,0));
                                        //Align 1st Selection to the polygon of 2nd Selection (Y AXIS)
                                        if (polyLocation.y > 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation + Vector(0,firstSelection->GetRad().y,0));
                                            firstSelection->SetRot(op->GetRot());
                                        if (polyLocation.y < 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation - Vector(0,firstSelection->GetRad().y,0));
                                        //Align 1st Selection to the polygon of 2nd Selection (Z AXIS)
                                        if (polyLocation.z > 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation + Vector(0,0,firstSelection->GetRad().z));
                                        if (polyLocation.z < 0)
                                            firstSelection->SetPos(op->GetPos() + polyLocation - Vector(0,0,firstSelection->GetRad().z));
                                secondSelection = FALSE;
                            EventAdd(EVENT_FORCEREDRAW);
                            op->Message(MSG_CHANGE);
              I am trying to get (firstSelection) to rotate to the normal of the selected polygon on (op).    I am using CalcFaceNormal() but that seems to return incorrect results.  Does anyone know how I could get this to rotate properly?
              ~SHawn
                On 24/02/2010 at 02:43, xxxxxxxx wrote:
                I recommend to read up on Vector and Matrix arithmetics.
                http://www.flipcode.com/documents/matrfaq.html
                Also the CINEMA 4D R9.5 COFFEE documentation has a very good tutorial on using matrices.
                Especially vector cross products are essential to build your own cutom rotation matrices.
                I can not debug or write your plugin, sorry.
                  On 24/02/2010 at 02:48, xxxxxxxx wrote:
                  Thanks for the link Matthias.   LOL...  I don't want you to write it for me.   Where's the fun in that.   🙂
                  ~Shawn
                    On 24/02/2010 at 07:31, xxxxxxxx wrote:
                    Great tutorial on Matrices.  Thanks for that.
                    ~Shawn
                      On 25/02/2010 at 03:47, xxxxxxxx wrote:
                      Is there a c++ equivalent to the function you mention in the tutorial GetMulP()?
                      or would I just use
                      firstSelection->SetPos(opMatrix * points[lngA]);
                      first selection being my object,  and points[lngA] being the vector location of the point I am trying to move the object to.
                      ~Shawn
                        On 25/02/2010 at 05:47, xxxxxxxx wrote:
                        Yes, multiplying a vector with a matrix transforms the vector into the matix' space.
                        The Matrix class has several overloaded operators for matrix-matrix and matrix-vector arithmetics.
                          On 26/02/2010 at 09:38, xxxxxxxx wrote:
                          Okay... SO I think I kindof understand a rotation matrix now.   I need to find the vector from the center of the polygon which I did with
                          This gives me a vector that represents the very center of the polygon
                          Then I need another point along the same plane which I use points[lngA].  This is the first point in the polygon.
                          So mathematically that gives me A & B.   Assuming my equation is C = A x B.     So to get the point which represents the Z axis or the point hovering directly above the polygon face, I simply multiply
                          Vector rotC =  polyLocation * points[lngA];
                          And this should give me my rotation matrix correct?
                          So now my question is how do I then rotate my object to match that  rotation matrix?  Here is what I am trying.
                            //ROTATION MATRIX
                                                        //GetPoints
                                                        Vector p1 = polyLocation;
                                                        Vector p2 = points[lngA];
                                                        //Contruct Matrix
                                                        Matrix rotMatrix;
                                                        rotMatrix.off = p1; //The base of the matrix
                                                        rotMatrix.v1 = !(p2 - p1); //X axis points toward the second point
                                                        rotMatrix.v2 = !(p2-p1%Vector(0,1,0)); //Y Axis is perpendicular to the X axis
                                                        rotMatrix.v3 = rotMatrix.v1 * rotMatrix.v2;
                                                        Vector scale = Vector(Len(rotMatrix.v1), Len(rotMatrix.v2), Len(rotMatrix.v3)); //Get Scale
                                                        Vector pos = rotMatrix.off; ///Get the Position
                                                        //Create a vector which contains the rotation matrix.
                                                        Vector rot1 = MatrixToHPB(rotMatrix);
                                                        firstSelection->SetPos(opMatrix * polyLocation);
                                                        firstSelection->SetRot((rot1));
                          Please let me know if I am way off base here and am going about this completely wrong so that I know not to continue in this way.    Thanks lot for your help.
                            On 01/03/2010 at 06:22, xxxxxxxx wrote:
                            Thanks for all your help Jack.  I have officially filled up your PM box.   I didn't notice that what you sent me was different.  Thanks for that.
                            ~Shawn
                              On 03/03/2010 at 17:15, xxxxxxxx wrote:
                              Hey folks.  So I believe that I have created the rotation matrix correctly.  And when I click the polygon on the second object the object moves to that polygon correctly, however it does not rotate correctly.  Sometimes it rotates a bit but not the way it should.  I want the firstSelection object to rotate so that it is sitting flush with the polygon no matter what the rotation of the polygon is.    Does anyone see any reason in the following code why this wouldn't be happening?
                              Any help would be greatly appreciated.  This one's a bit frustrating.
                              							else
                              								//ROTATION MATRIX
                              								//GetPoints
                              								Vector scale = Vector(Len(opMatrix.v1), Len(opMatrix.v2), Len(opMatrix.v3)); //Get Scale
                              								//Contruct Matrix
                              								Matrix rotMatrix;
                              								rotMatrix.v3 = !(p1); //Z Axis is along the normal
                              								rotMatrix.v2 = rotMatrix.v1%rotMatrix.v3;//Y Axis is perpendicular to the X axis
                              								rotMatrix.v1 = !(rotMatrix.v3%rotMatrix.v2);//recreated second axis..   using cross product.
                              								rotMatrix.v1 = !(rotMatrix.v1 * scale.x);
                              								rotMatrix.v2 = !(rotMatrix.v2 * scale.y);
                              								rotMatrix.v3 = !(rotMatrix.v3 * scale.z);
                              								firstSelection->SetMg(rotMatrix);
                              								firstSelection->SetPos((opMatrix * polyLocation) + firstSelection->GetRad().x);
                              								//firstSelection->SetRot(rot1);
                                On 03/03/2010 at 18:21, xxxxxxxx wrote:
                                Do I need the world coordinates of the points I am using for this to work properly?
                                ~Shawn
                                  On 09/03/2010 at 17:20, xxxxxxxx wrote:
                                  I feel like I have done the rotation matrix correctly here.  But my object is not rotating to the normal of the polygon.  Does anyone see anything that I am doing wrong creating the rotation matrix?
                                  I would GREATLY, appreciate any help anyone could offer.  This one is irritating me because everything I have read about rotation matrices says that I am doing it right.  I am using a vector that represents the center of the polygon (polygonLocation)   I am using another point in the polygon to determine the plane upon which the polygon rests.  I am then using the cross product of those vectors to determine the up vector that is perpendicular to the plane.  So, if my understanding of rotation matrices is correct, this should create a rotation matrix that can then be adapted by an object and that object should rotate to the normal of the polygon.
                                  However, that is not happening with what I have pasted above.   I am at a loss.  Does anyone see anything that I am doing wrong?
                                  Thanks so much for anyone who has the time to help me out.
                                  ~Shawn
                                    On 15/03/2010 at 01:25, xxxxxxxx wrote:
                                    This part is wrong.
                                    Assume that A is the midpoint of your polygon and B is one of the polygon points.
                                    N is the polygon normal.
                                    You have to build the cross product of (B-A) and N for one of the matrix axes, let's say for V1.
                                    Then build the cross product of this new axis and the normal for the second matrix axis, V2.
                                    The normal is the third axis of the matrix, V3.
                                    The polygon midpoint is the matrix offset, V0 or off.
                                      On 15/03/2010 at 02:41, xxxxxxxx wrote:
                                      Thanks Matthias,
                                      I must not fully understand how to get the normal then.   I thought that the normal was A - B.   How to I get the value for N then?
                                      THanks,
                                      ~Shawn
                                        On 15/03/2010 at 02:47, xxxxxxxx wrote:
                                        Would I use
                                        CalcFaceNormal()_<_h4_>_
                                        ~Shawn
                                          On 15/03/2010 at 02:49, xxxxxxxx wrote:
                                          For triangles the normal is the cross product of two edges of the triangle. For quadrangles it's not exactly defined. The easiest way which gives a good result is too use the cross product of the diagonales.
                                          PS. please read up on 3D geometry basics, it will help you in the long run. Most of it can be found through Google and Wikipedia.
                                            On 15/03/2010 at 03:06, xxxxxxxx wrote:
                                            So to calculate the normal of a quad would I do something like this...  Assuming that the points in a quad are A, B, C, and D
                                            QUAD
                                            N = (A-C)%(D-B)
                                            TRIANGLE
                                            N = (A-C)%(B-C)
                                            SOmething like that?
                                            Does CalcFaceNormal() do this for you?  or is that something completely different?
                                            Thanks  a lot for your help,
                                            ~ Shawn
