    Rotate all Groups
    8 Posts 0 Posters 719 Views
      On 17/02/2010 at 03:11, xxxxxxxx wrote:
      Cinema 4D Version:   11.028
      Language(s) :
      Ok, my first post! 😊
      I got a problem by exporting all my models into an other 3D application (DeltaGen from RTT).
      I use the FBX exporter and I need to have turned all models 90° (P). DeltaGen uses Z-up not Y-up!
      This opperation is just one step of a bigger process before exporting.
      I want my 40 user not to do everytime the same steps.
      So this little script I worked hardly out works only on one selected group.
      But if you select more then one group ... nothing happend.
      Could someone tell me what to write in my script for rotating all models P=90°?
      main(doc,op)
       /* Reset object rotation */
       var rotation = vector(0,1.5708,0);
       op->SetRotation(rotation);
      Many thanks
        On 17/02/2010 at 06:49, xxxxxxxx wrote:
        You need to iterate thru all selected objects
        by searching for the selection bit.
        Look at this and you should be on your way:)
        var op = doc->GetFirstObject();
        if(!op) return;
        while(op)
           if(op->GetBit(BIT_AOBJ))
           op->SetRotation(vector(0,PI/2,0));
           op = op->SearchNext(BIT_AOBJ);
        Lennart
          On 17/02/2010 at 07:22, xxxxxxxx wrote:
          Thanks a lot Lennart
          You r the man! 😄
          But now there is one small thing left.
          When I take the command "select all" from the object manager, it also selects all children.
          I do not know how to tell the program only to take the major group of every tree in the scene.
          Could you help me with this command to?
          Many many thanks, you help me to save a lot of time.
          Greets  Andy
            On 17/02/2010 at 07:29, xxxxxxxx wrote:
            You have to iterate through your scene, something like this:
            main(doc,op)
              var obj = doc->GetFirstObject();
              for (; obj; obj = obj->GetNext())
                  //do something with obj,  it's the topmost parent of each group
              On 17/02/2010 at 07:52, xxxxxxxx wrote:
              Ok, Matthias
              I do think I m not quiet good in programming, so I tried it out and had no result.
              So I took the rotate script and made a callcommand out of this input.
              Then combined some commands (select all->group all-> rotate -> ungroup->delete empty Group)
              this works! It is not nicely solfed, this problem, but solved in a way!
              So could you finally help me to make a plugin out of this command jungle so I can share it to our users? Will such a plugin work where I used  a callcommand which came out of a script?
              I never created a plugin my self. But I already reached to get a Plugin ID! 👍
              Thanks a lot for your help!
              Regards Andy
                On 19/02/2010 at 03:50, xxxxxxxx wrote:
                Ok , I got a result that works!
                Look at this:
                      // if(obj->GetBit(BIT_AOBJ))
                       obj->SetRotation(vector(0,PI/2,0));
                So could you tell me how to make a plugin out of it?
                So i can share this to my users?
                Thanks again
                  On 19/02/2010 at 05:27, xxxxxxxx wrote:
                  Scripts are just like MenuPlugins. Please check the COFFEE docu for MenuPlugin.
                  To convert your script you just put the script code into the menu plugins Execute() method and return the unique plugin ID in the GetID() method.
                  Something like this:
                  class YourMenuPlugin : MenuPlugin
                        YourMenuPlugin();
                        GetID();
                        GetName();
                        GetHelp();
                        Execute(doc);
                  YourMenuPlugin::YourMenuPlugin()
                    // Call the parent constructor
                    super();
                    // TODO: Initialize any local variables etc.
                  YourMenuPlugin::GetID()
                    return YOURPLUGINID;
                  YourMenuPlugin::GetName()
                    // TODO: Return the text of the menu entry
                    return "Your plugin's name";
                  YourMenuPlugin::GetHelp()
                    // TODO: Return a help text that's displayed when the menu item is selected
                    return "Some help text";
                  YourMenuPlugin::Execute(doc)
                    // Called when the menu item is chosen
                        obj->SetRotation(vector(0,pi05,0));
                  // Main
                    Register(YourMenuPlugin);
                    On 23/02/2010 at 00:35, xxxxxxxx wrote:
                    Some corrections to the plugin (missing refresh). Also it has now an icon and is undoable.
                    var icon;
                          YourMenuPlugin();
                          GetID();
                          GetName();
                          GetHelp();
                          GetIcon();
                          Execute(doc);
                      super();
                    YourMenuPlugin::GetIcon()
                      // return the icon's bitmap;
                      return icon;
                      doc->StartUndo();    //start collecting undo steps
                          doc->AddUndo(UNDO_OBJECT_BASEDATA, obj);    //add an undo
                          obj->Message(MSG_UPDATE);
                      doc->EndUndo();    //end undo collection
                      EventAdd();
                    // Main
                      icon = new(BaseBitmap,1,1);
                      var fn = GeGetRootFilename();
                      fn->RemoveLast();
                      fn->AddLast("res");
                      fn->AddLast("icon.tif");
                      icon->Load(fn);
