    Demo Plugin Version.
    18 Posts 0 Posters 1.9k Views
      On 13/02/2010 at 06:02, xxxxxxxx wrote:
      Okay so I tried this in the main.cpp..
      Bool PluginStart(void)
        // example of installing a crashhandler
        old_handler = C4DOS.CrashHandler; // backup the original handler (must be called!)
        C4DOS.CrashHandler = SDKCrashHandler; // insert the own handler
        //GePrint("PLANET X GENERATOR IS AVAILABLE FOR DEMO USE ONLY!");
            if (GeGetVersionType() &VERSION_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO)
            else
                GePrint("NOT THE DEMO");
                GePrint("THE VERSION TYPE IS " + LongToString(GeGetVersionType()));
                if (!IsSerialOKHook()) return FALSE; //don't load plugins if key is wrong
        // Planet Object
        if (!RegisterPlanet()) return FALSE;
        // Sun Object
        if (!RegisterSun()) return FALSE;
        // Space Object
        if (!RegisterSpace()) return FALSE;
        //SERIAL NUMBER
        if (!RegisterPlanetXSerial()) return FALSE;
        return RegisterPlanet() && RegisterSun() && RegisterSpace();
      When I am in the demo mode I get the plugin enabled and I am able to use it and as expected, the console prints out....
      However, when I am using my registered copy of the plugin, I am also able to use it and the console prints out...
      Why do you think this is happening?
      ~Shawn
        On 13/02/2010 at 07:01, xxxxxxxx wrote:
        Well...  thanks to a heaping helping of kindness from Cactus Dan,  this problem has been solved.   Here's the final working code for the PluginStart();
              if(GeGetVersionType()&VERSION_SAVABLEDEMO_ACTIVE || GeGetVersionType()&VERSION_SAVABLEDEMO || GeGetVersionType()&VERSION_DEMO)
              else
          // Planet Object
          // Sun Object
          // Space Object
          //SERIAL NUMBER
          On 13/02/2010 at 07:31, xxxxxxxx wrote:
          The line looks strange to me:
          GeGetVersionType() &VERSION;_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO
          Shouldn't it be:
          GeGetVersionType() == VERSION_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO
          [EDIT]Oh no, wait. Forget about this. & is correct.[/EDIT]
          Jack
            On 13/02/2010 at 07:33, xxxxxxxx wrote:
            Actually, that looks strange to me, too:
                // Planet Object
                // Sun Object
                // Space Object
                //SERIAL NUMBER
            So, you first try to register the plugins. When this succeeds, you register them all again and return the result? Why don't you just return TRUE at the end of the function, since they're already registered?
            Jack
              On 13/02/2010 at 07:45, xxxxxxxx wrote:
              so instead of
              do...
              ~Shawn
                On 13/02/2010 at 09:53, xxxxxxxx wrote:
                GeGetVersionType() returns a bit mask. So you have to check against your own bit mask.
                Remember that || and & & are compare operators.
                | and & are bit mask operators.
                Following line of code checks if the result of GeGetversionType() has one of the specified bits set.
                if (GeGetVersionType() & (VERSION_SAVABLEDEMO_ACTIVE | VERSION_SAVABLEDEMO | VERSION_DEMO))
                  //do something
                  On 13/02/2010 at 14:57, xxxxxxxx wrote:
                  so instead of
                  do...
                  Yes. You have already called all Register functions before, so if the function reaches this point, you can just return TRUE. If one of the Register functions does not work out (returns FALSE) the PluginStart function is cancelled anyway and FALSE is returned.
                  Jack
                    And what is the exact dependency? From R11 on checking for these two instead of VERSON_DEMO? Is VERSON_DEMO completely gone now or should one still check for it? Thanks
                    VERSION_DEMO is not used anymore since the R11 demo version.
                      hmm, it seems to me that the demo does not call SNCheck at all. Is that right?
                      The demo version doesn't support the SNHookClass because it has no Personalioze dialog anyway.
                      Check in C4DPL_INIT_SYS for the Cinema version (that's where you would register the SNHookClass too).
                        On 15/02/2010 at 04:18, xxxxxxxx wrote:
                        Thanks Matthias.
