    How can I create segments for a SplineObject
    3 Posts 0 Posters 381 Views
      On 11/02/2010 at 13:16, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi there,
      i need some hint how i can create segments for a spline object. i already know how to create a spline (with a single segment), and in the help file i can only find commands to get the segment sount and such stuff, but i cannot fine something to create segments.
      any help is welcome.
      cheers and thanks,
      ello
        On 12/02/2010 at 01:33, xxxxxxxx wrote:
        SplineObject::ResizeObject() allows you to change the segment count.
        SplineObject::GetSegmentW() return the writeable array of segments to set how many points per segment.
        Also have a look at VariableChanged structure and the MSG_SEGMENTS_CHANGED message for a more low-level approach.
        here an example which creates a spline with two segments.
        SplineObject *spline = NULL;
        spline = SplineObject::Alloc(0, Tlinear);
        if (!spline) return FALSE;
        spline->ResizeObject(4, 2);
        Segment *seg = spline->GetSegmentW();
        seg[0].cnt = 2;
        seg[1].cnt = 2;
        Vector *points = spline->GetPointW();
        points[0] = Vector(0,0,0);
        points[1] = Vector(0,100,0);
        points[2] = Vector(0,200,0);
        points[3] = Vector(0,300,0);
          On 12/02/2010 at 02:39, xxxxxxxx wrote:
          thank you very much. this helps a lot
          best regards,
          ello
