    Highlighting Polys/points/and edges.
    14 Posts 0 Posters 1.1k Views
      On 11/02/2010 at 06:15, xxxxxxxx wrote:
      Also...
      I am trying to figure out how to allow users to hold down the SHIFT key to select more than one polygon.    This is the code I have based on some searches I did on the subject.   It is still not working for me.   The only one I have attempted to set up like this is the polygon selection.
      Here's the code I have.
      BaseContainer state;
        LONG key = state.GetLong(BFM_INPUT_QUALIFIER);
        ViewportPixel *vpPoly = vps->GetNearestPolygon(op,x,y,rad);
        ViewportPixel *vpPoint = vps->GetNearestPoint(op,x,y,rad);
        ViewportPixel *vpEdge = vps->GetNearestEdge(op,x,y,rad);
        Bool ctrlDown = GetInputEvent(BFM_INPUT_KEYBOARD, state);
        switch (editorMode)
            //POLYGONS MODE
            case Mpolygons:
                if(vpPoly)
                    if (ctrlDown == TRUE)
                        if (key & QCTRL)
                            GePrint("ctrl");
                            bsPoly->DeselectAll();
                    bsPoly->Select(vpPoly->i);
                    EventAdd(EVENT_FORCEREDRAW);
            //POINTS MODE
            case Mpoints:
                if(vpPoint)
                    bsPoint->DeselectAll();
                    bsPoint->Select(vpPoint->i);
            //EDGES MODE
            case Medges:
                if(vpEdge)
                    bsEdge->DeselectAll();
                    bsEdge->Select(vpEdge->i);
      This is all in the MouseInput() member.   Do you see something I need ot fix?
      ~Shawn
        On 12/02/2010 at 06:33, xxxxxxxx wrote:
        Highlighting and SHIFT key for multiselection has to be done manually.
        For highlighting you check in GetCursorInfo() over which polygon, point or edge you are hovering and pass the ID of the element to the Draw() method (call DrawViews() to trigger a redraw).
        Your code should work. I would add following two lines after selecting the polygon
        op- >Message(MSG_CHANGE);
        DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION);
        This informs the object of a change and will trigger the redraw to display the polygon selection.
          On 14/02/2010 at 18:04, xxxxxxxx wrote:
          So I am guessing that this would be how I would get the index of the poly/point/ or edge that I am over.
            AutoAlloc<ViewportSelect> vps;
            if(!vps) return FALSE;
            BaseObject* op = doc->GetActiveObject();
            if(!op) return FALSE;
            ViewportPixel *vp = vps->GetNearestPolygon(op,x,y,100);
            LONG polyIndex = vp->i;
          How do I pass that index to the Draw() method?
          ~Shawn
            On 14/02/2010 at 22:06, xxxxxxxx wrote:
            Okay here's what I have in my GetCursorInfo()
              if (bc.GetId()==BFM_CURSORINFO_REMOVE) return TRUE;
              bc.SetString(RESULT_BUBBLEHELP, GeLoadString(IDS_HLP_QUICK_ALIGN));
              CallCommand(10004766);
              LONG lngX = x;
              LONG lngY = y;
              ViewportPixel *vp = vps->GetNearestPolygon(op,lngX,lngY,MAXLONGl, TRUE);
              if(!vp) return FALSE;
              GePrint("POLY INDEX IS: " + LongToString(polyIndex));
            the probem I am having is that with the line ->
            it always returns false.
            if I remove that line, C4D crashes as soon as I have an object in the scene.  Is it my definition of "op" that is the problem?
            should this be something different?
            Any help you c ould offer would be greatly appreciated.  Also if you have an answer the the post before this one that would be helpful too.   🙂
            ~Shawn
              This will always return FALSE if the Bool onlyselected is set to TRUE and no polygons are selected in the first place.
              As for passing an index to Draw() you simply store the index in a member variable and call DrawViews(). This will trigger Draw(). In Draw() read out the member variable then.
                On 15/02/2010 at 06:36, xxxxxxxx wrote:
                This is what I have in GetCursorInfo() now:
                  LONG lngX = x;
                  LONG lngY = y;
                  ViewportPixel *vp = vps->GetNearestPolygon(op,lngX,lngY,MAXLONGl, FALSE);
                  LONG lngPolyIndex = vp->i;
                  GePrint("POLY INDEX IS: " + LongToString(lngPolyIndex));
                  DrawViews(lngPolyIndex,bd);
                for some reason (vp) is still returning false so anything below it is not being read.  Do you see any reason why the ViewportPixel would return FALSE?
                ~Shawn
                  On 15/02/2010 at 06:43, xxxxxxxx wrote:
                  Ah, now I see why it doesn't work for you. You forgot to initialize the ViewportSelect object before using one of the GetNearest functions. Check the ViewportSelect::Init methods.
                    On 15/02/2010 at 06:55, xxxxxxxx wrote:
                    LOL..  what a silly mistake on my part..  I have used ViewPortSelect before too..  I should have remembered that.    Okay..  now it prints out the index to the console and shows me poly I am hovering over,  but the polygon does not highlight when my mouse is over it.   Did I not do the DrawViews()  correctly.  Or is there something I need to add to the Draw() to make it highlight?
                    Thanks again.
                    ~Shawn
                      On 16/02/2010 at 01:00, xxxxxxxx wrote:
                      Draw() is not automatically displaying the highlighting. You have to do the highlight drawing yourself within Draw(). DrawViews() is just triggering the viewport redraw by internally calling Draw(). You are using DrawViews() wrong. Also as I said you should store the polygon ID within a member variable of the tool class.
                      Have a look at eh code below. I store the polygon ID in the polygonid variable and call DrawViews() to trigger a redraw. In Draw() I read out the variable then to draw the highlight polygon. I use the BaseDraw drawing functions for this. The highlight variable is used to prevent highlighting during viewport navigation.
                      class LiquidToolData : public ToolData
                            LiquidToolData() { polygonid = 0; highlight = FALSE; }
                            virtual Bool GetCursorInfo(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, Real x, Real y, BaseContainer &bc);
                            virtual LONG Draw(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt, LONG flags);
                        private:
                            LONG polygonid;
                            Bool highlight;
                      Bool LiquidToolData::GetCursorInfo(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, Real x, Real y, BaseContainer &bc)
                        LONG left, top, right, bottom, width, height;
                        bd->GetFrame(&left,  &top, &right, &bottom);
                        width = right - left + 1;
                        height = bottom - top + 1;
                        LONG mode = doc->GetMode();
                        BaseObject *op = doc->GetActiveObject();
                        if (!op || op->GetType() != Opolygon) return TRUE;
                        AutoAlloc<ViewportSelect> vs;
                        if (!vs || !vs->Init(width,height,bd,op,mode,TRUE,0)) return FALSE;
                        if (mode == Mpolygons)
                            highlight = TRUE;
                            ViewportPixel *vpp = NULL;
                            LONG mx = x;
                            LONG my = y;
                            vpp = vs->GetNearestPolygon(op, mx, my, MAXLONGl, FALSE, NULL, 0);
                            if (vpp)
                                polygonid =  vpp->i;
                                DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION, bd);
                      LONG LiquidToolData::Draw(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt, LONG flags)
                        if (!(flags & DRAWFLAGS_HIGHLIGHT))
                            return FALSE;
                        if (doc->GetMode() != Mpolygons)
                        if (!highlight)
                        if (op && op->GetType() == Opolygon)
                            const CPolygon *polys = ToPoly(op)->GetPolygonR();
                            const Vector *points = ToPoly(op)->GetPointR();
                            Vector *p = bNew Vector[4];
                            p[0] = points[polys[polygonid].a];
                            p[1] = points[polys[polygonid].b];
                            p[2] = points[polys[polygonid].c];
                            p[3] = points[polys[polygonid].d];
                            Vector *f = bNew Vector[4];
                            f[0] = 1.0;
                            f[1] = 1.0;
                            f[2] = 1.0;
                            f[3] = 1.0;
                            bd->SetMatrix_Matrix(NULL, op->GetMg(), 3);
                            bd->PolygonNew(p,f,TRUE);
                            bd->LineZOffset(0);
                            bDelete(p);
                            bDelete(f);
                        highlight = FALSE;
                        On 16/02/2010 at 16:26, xxxxxxxx wrote:
                        Thanks Matthias that worked great.
                        How does this translate to points and Edges?    Do I use Point3D() for the points?    I am not sure what I would use for edges.    What are your thoughts on points and edges?
                        ~Shawn
                          On 16/02/2010 at 17:17, xxxxxxxx wrote:
                          Also,  if I have selected a polygon, how can I then move that particular polygon,  how do I get access to the position of that polygon,   is it possible to convert a BaseSelect polygon selection into a CPolygon so that I can move the position of .a .b .c .d   ?
                          Basically, I want the user to click on a polygon, then click a second polygon and the first selected polygon will move to the location of the second selection.    Any thoughts as to how I would go about this?
                          ~Shawn
                            On 19/02/2010 at 08:59, xxxxxxxx wrote:
                            Any thoughts on this?
                              On 11/03/2010 at 03:59, xxxxxxxx wrote:
                              if you are in a tooldata plugin i sugest you to use modeling lib.
                              with your baseselect you can recourse in Polygons and ngon and get/ set Point position.
                              to convert you standard selection in a ngon one ( modelling lib need it )
                              use GetFace Slection.
                              all the best
                              Franz
