    Structuring a plugin project??
    Scheduled Pinned Locked Moved General Discussion
    2 Posts 0 Posters 382 Views
      On 10/02/2010 at 09:12, xxxxxxxx wrote:
      Hey there,
      i was wondering how you put structure into your plugin developement. how do you keep your different solutions updated, for example if you create something for r11 and r11.5
      i am struggling a bit here, since it happens sometimes that i add something to my r11 source code and later i find that i didnt update the r11.5 version accordingly. specially when there are compiling issues for the mac versions i go crazy
      so, what do you do to avoid such cases?? or is this simply a question of routine?
      thanks and cheers,
      ello
        On 16/02/2010 at 05:58, xxxxxxxx wrote:
        I have one code for all versions sitting in my repository (subversioned). I use the code in all versions, so if I change something it changes it for all versions. I use preprocessor definitions to keep it version safe.
