    OS Error loading Plugin
    7 Posts 0 Posters 679 Views
      On 17/12/2009 at 07:33, xxxxxxxx wrote:
      Cinema 4D Version:   11.529
      Language(s) :
      Hello All,
      On x64 my plugins (pathdeformer and vraybridge for now) fail to load on the 11.529 64bit.
      The error returned in console is:
      Error: OS loading plugin plugin.cdl64, GetLastError return 0.
      Does someone got same error ?
      thanks in advance
      renato
        On 17/12/2009 at 07:59, xxxxxxxx wrote:
        If you use a c4d beta built you should rather contact MAXON directly for this issue. In 11.528 it works fine here. No problems.
          On 17/12/2009 at 08:06, xxxxxxxx wrote:
          Hello Robert,
          so you got same error with 11.529?
            On 17/12/2009 at 08:08, xxxxxxxx wrote:
            ops.. Samir 🙂
              On 17/12/2009 at 09:34, xxxxxxxx wrote:
              Ok, with the 11.528 now it work 🙂
              thanks for the suggestion
              renato
                On 25/11/2011 at 01:08, xxxxxxxx wrote:
                Hello All,
                same problem when i switch back from vs2008 to the vs2005.
                Error: loading plugin vraybridge.cdl GetLastError return 0..
                I'm working on R12.048, Vs2005 and the projects was made from the c4dsdk.vcproj.
                someone have a suggestion?
                thanks in advance
                renato
                  On 25/11/2011 at 03:11, xxxxxxxx wrote:
                  Hello All,
                  thanks in advance
                  renato
                  Well you have to check that on your side.
                  The message happens, if the Windows LoadLibraryW() call - loading (and initializing) the vraybridge.cdl - returns NULL instead of a pointer to the dll.
                  Best regards,
                  Wilfried Behne
