    Regular Expressions Search (RegularExprParser)
    7 Posts 0 Posters 482 Views
      On 14/12/2009 at 06:46, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hi there,
      has anyone a good example code for regular expressions search or knows what´s wrong i my code, where nothing happens(never return TRUE (if...)). Here my code:
      AutoAlloc <RegularExprParser> regularexpression;
      String input = "a*";
      String objectname = "appletree";                              regularexpression->Init(input);
      LONG pos2 = 0;
      String word = "";
                                    if(regularexpression->FindFirst(objectname,RegParseMatch,TRUE,pos2,word))                                   found.push_back(object);      // never step-in
      coffeemax
        On 17/12/2009 at 23:42, xxxxxxxx wrote:
        any infos how to use that?
          On 18/12/2009 at 01:52, xxxxxxxx wrote:
          I am trying to get my head around as well. I will post back when I know more about it.
            On 21/12/2009 at 01:02, xxxxxxxx wrote:
            I had a look at this a few days ago and couldn't get it to work with RegParseMatch, but it worked okay with RegParseContains. I didn't bother posting since I figured you'd probably already tried it and in any case Matthias would be along with the answer 🙂
            But if you haven't tried them, the other options might work for you.
              On 21/12/2009 at 02:32, xxxxxxxx wrote:
              Thanks spedler. It was successful when i changed the RegParseMode from RegParseMatch to RegParseContains.
              coffeemax
                On 21/12/2009 at 05:31, xxxxxxxx wrote:
                When i have make some tests with the Regular Expression Parser i found out, there was a problem with the RegularExprParser::Init(const String& str) function. If I initialize the Init-function:
                AutoAlloc<RegularExprParser> regularexpression;
                String txt = "(s) )";
                regularexpression->Init(txt);    // collapse
                , C4D collapses. Has anyone an idea what´s the problem.
                  I can confirm this and have reported it as bug.
