    Strings different betweenPC and Mac?
    7 Posts 0 Posters 557 Views
      On 25/11/2009 at 11:50, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      just a small question... why does the following code work on PC, but not on Mac?
      String ReplaceStr(String Original, String Search, String Replacement)
      // Replace a Substring in a String
           String res = Original;
           LONG i = 0;
           while (res.FindFirst(Search, &i;, i)) {
                res.Delete(i, Search.GetLength());
                res.Insert(i, Replacement);
           return res;
      String ConvertHTMLchars(String tmpl)
      // Substitute special characters by their HTML entities
           String res = tmpl;
           res = ReplaceStr(res, "ä", "& auml;");
           res = ReplaceStr(res, "ö", "& ouml;");
           res = ReplaceStr(res, "ü", "& uuml;");
           res = ReplaceStr(res, "Ä", "& Auml;");
           res = ReplaceStr(res, "Ö", "& Ouml;");
           res = ReplaceStr(res, "Ü", "& Uuml;");
           res = ReplaceStr(res, "ß", "& szlig;");
           res = ReplaceStr(res, "€", "& euro;");
           res = ReplaceStr(res, "é", "& eacute;");
           res = ReplaceStr(res, "É", "& Eacute;");
           res = ReplaceStr(res, "Ê", "& Ecirc;");
           res = ReplaceStr(res, "ê", "& ecirc;");
           res = ReplaceStr(res, "È", "& Egrave;");
           res = ReplaceStr(res, "è", "& egrave;");
           res = ReplaceStr(res, "Â", "& Acirc;");
           res = ReplaceStr(res, "â", "& acirc;");
           res = ReplaceStr(res, "À", "& Agrave;");
           res = ReplaceStr(res, "à", "& agrave;");
           res = ReplaceStr(res, "Å", "& Aring;");
           res = ReplaceStr(res, "å", "& aring;");
           return res;
      On PC, the special characters are replaced by HTML entities. On Mac, nothing happens. Why?
      Jack
        On 25/11/2009 at 12:22, xxxxxxxx wrote:
        I editied the code, it didn't display correctly before.
          On 25/11/2009 at 12:55, xxxxxxxx wrote:
          Have you tried Unicode formatting instead ("\u0..." - "\u00a9" for the copyright symbol as you might encode it in your c4d_strings.str file)?  The fact that they display in your IDE just means that the font being used has Unicode characters in it.
            On 25/11/2009 at 14:18, xxxxxxxx wrote:
            Ha, that sounds perfectly reasonable.
            After encoding all the special chars to Unicode, it still works on PC... will see in a couple of minutes if it does so on the Mac, too 🙂
            Jack
              On 25/11/2009 at 14:35, xxxxxxxx wrote:
              Hm, unfortunately it still does not work in Mac 😞
              But thanks any way for the input!
              Jack
                On 25/11/2009 at 14:42, xxxxxxxx wrote:
                Hi Jack, I suggest you to convert the String with 'StringEncoding' to 'StHTML'. This should work fine. Good luck
                P.S: 'StHTML' might be not documentated(in R10), even available in the sources.
                  On 25/11/2009 at 14:52, xxxxxxxx wrote:
                  Arrgh, I have always thought that was introduced with R11.
                  They could really have put that into the R10 SDK docs... 😉
                  Thanks a lot!
                  Greetings,
                  Jack
