    Only able to compile in Debug mode.
    28 Posts 0 Posters 17.7k Views
      On 23/11/2009 at 09:00, xxxxxxxx wrote:
      Every single error is a standard C++ one - not one is related to Cinema 4D itself. These same four errors, over and over:
      /usr/include/c++/4.2.1/cstddef:50:28: error: bits/c++config.h: No such file or directory
      /usr/include/c++/4.2.1/cstddef:53: error: expected constructor, destructor, or type conversion before '(' token
      /usr/include/c++/4.2.1/exception:40: error: '#pragma' is not allowed here
      /usr/include/c++/4.2.1/exception:133: error: expected declaration before end of line
      Could be your installation of Xcode or something that the Cinema 4D project doesn't consider for this version (changes). Can you get your hands on 3.1? Or maybe a reinstall? The download should have been at least 1GB in size (3.1 is 1.03GB).
        On 23/11/2009 at 09:13, xxxxxxxx wrote:
        I had the very same thing working with the R11 SDK on Snowleopard.
        It is everything but straightforward, and a pain in the back. I assume that ppc compiles do not work there at all for whatever reason.
        My solution was the following:
        First I cared about the api project. After removing both ppc and ppc64 from the Architectures field of the api project (release target), and building release for 'x86_64 i386', this compiled fine.
        Then I did the same for my project, and voila, everyhing compiles nicely and runs both in 32 and 64 bit (debug and release). Of course PPC is gone now, but to me it looks like it's not worth the hassle anymore.
        Hope it helps
        Kabe
          On 23/11/2009 at 09:40, xxxxxxxx wrote:
          Must be Snow Leopard then. I've never had one single build issue with the cinema4dsdk on Leopard for R11 or R11.5 - open, build, done. Maybe in SL, Apple is phasing out PPC support. This is understandable as all new Macs are Intel-based. Another reason for me to stay with 10.5 for the time being. 🙂
            Can confirm, this was my workaround, too.
            Correct me if I am wrong, but XCode 3.1.x is only for Leopard(10.5) and XCode 3.2 is only for SL(10.6).
            P.S. I switched back to Leopard(10.5), too.
              On 23/11/2009 at 10:22, xxxxxxxx wrote:
              I can't downgrade from Snow Leopard to Leopard as I'm doing presentations of Snow Leopard.
              So, what can I do? Will Maxon release a cinema4dsdk that will work on Snow Leopard and xcode 3.2?
              Rui Batista
                On 23/11/2009 at 10:33, xxxxxxxx wrote:
                Probably in R12. 😉
                  On 23/11/2009 at 10:49, xxxxxxxx wrote:
                  So, I will have to wait for R12 to start coding in c++ 😞
                  Rui Batista
                    On 23/11/2009 at 10:56, xxxxxxxx wrote:
                    Know the feeling.  I just upgraded to Windows 7 64-bit and C4D R10.5 and earlier don't work at all (will not hold serial numbers).  And Visual Studio 2005 has issues (the recommended build version).  I ended up ordering a new PSU to have power to hook up another SATA drive on which to reinstall WinXP Pro x64 so that this can be accomplished.  Basically I need to have WinXP Pro 32 and 64 for development and will use Win7 for everything else.
                      The only thing you can do is to drop PPC support as I noted above.
                      It's Apple that dropped PPC support for Snow Leopard/XCode 3.2.
                      AFAIK Maxon can nothing to regenerate that.
                      Kabe
                        On 23/11/2009 at 12:54, xxxxxxxx wrote:
                        But I don't mind dropping PPC support. Apparently I don't know how to do that because when I tried doing what was stated here it kept on giving me all those errors.
                        If someone could help me to make this work, even if only for i386 and x86_64, I would be more than happy.
                        Rui Batista
                          On 23/11/2009 at 22:21, xxxxxxxx wrote:
                          Rui, it's really all about the settings of your project *and* your libs.
                          Have you checked the _api.xcodeproject inside _libs? As I wrote above, this is the first thing that you have to change (remove ppc targets), it's not just about your project.
                          Then, after changing those settings, it's always a good idea to "Clean all targets", which you find in the build menu. This ensures that you get a proper rebuild without any old stuff in there.
                          Hope it helps
                          Kabe
                            Kabe
                            When using SnowLeopard and XCode 3.2, you have to take care of the deployment target and the BaseSDK; 10.6 as BaseSDK wouldn't support ppc, but 10.5 does.
                            We have adopted the SDK to the changes in SL & Xcode 3.2 with the 11.528 update. If you use that version (or an updated 11.5 demo), building is no problem - we check that with every nightly build...
                            Best regards,
                            Wilfried Behne
                              Windows 7 is a pain in this respect. It's even worse than Vista IMO, even though MS say that the UAC in win7 should be 'less intrusive' than in vista. Even some of my own software, that I'd written myself, wouldn't run after 'upgrading' to win7 when it had been running perfectly in vista.
                              The thing that cured it for me was to turn off UAC completely. There is no switch to do this in win7, unlike vista, so you have to alter your user account settings to 'never notify' which is the equivalent. After I did that, everything worked as expected. C4D R10.111 is working fine here, although admittedly it was installed under vista before I upgraded to win7. If you haven't tried that, it might work for you.
                                I can confirm that! The R11 API + Plugins compile nicely when using OS X 10.5 as the base SDK!
                                So, all you have to do is to change the build settings to use OS X 10.5 as base.
                                Kabe
                                  On 24/11/2009 at 07:15, xxxxxxxx wrote:
                                  I can also confirm that 🙂
                                  Great!! What could be the limitations of using the 10.5 SDK?
                                  Thank you all 🙂
                                  Rui Batista
                                    Thank you all 🙂
                                    Rui Batista
                                    You can't use Snow Leopard specific functions when using OS X 10.5 as the BaseSDK.
                                    If you stay away from that and rely on Cinema's SDK and api only (as recommended :-), this is no serious limitation.
                                    Best regards,
                                    Wilfried Behne
                                      On 24/11/2009 at 09:41, xxxxxxxx wrote:
                                      Good to hear - and learned something along the way!
                                      Thanks Wilfried!
                                      Kabe
                                        On 24/11/2009 at 11:25, xxxxxxxx wrote:
                                        Yes, good to know. Even the workaround worked fine somehow,
                                        this seems to be more serious.
                                        Thanks!
                                        Shawni
