    Setting the Render settings
    7 Posts 0 Posters 689 Views
      On 22/11/2009 at 07:53, xxxxxxxx wrote:
      Cinema 4D Version:
      I would like the OBJECT GLOW effect to be enabled in the render settings,
      how would I do that?
      This is what I have but C4D crashes every time I insert my plugin object.
           BaseObject* op = static_cast<BaseTag*>(node)->GetObject();
           BaseDocument* doc = op->GetDocument();
           RenderData *rdata = doc->GetActiveRenderData();
           BaseContainer *data = rdata->GetDataInstance();
           data->SetBool(VPPRIORITY_OBJECTGLOW, TRUE); // Set Object Glow
      any thoughts?
      ~Shawn
        On 22/11/2009 at 10:37, xxxxxxxx wrote:
        yuo have to make a recursion in RenderData Videopost
        RenderData * rd = doc->GetActiveRenderData();
        PluginVideoPost * vp = rd->GetFirstVideoPost();
        and recurse in videpost with vp->GetNext();
        and set videopost container
        all the best Franz
          On 22/11/2009 at 17:25, xxxxxxxx wrote:
          So how do I know when I have reached the OBJECT GLOW?
          ~Shawn
            On 23/11/2009 at 00:45, xxxxxxxx wrote:
            videopost are baselist2d you can ask type:
            LONG vptype;
            for ( vp; vp; vp->GetNext())
            if(vp->GetType == ID_ObjectGlow) break;// i don't know this id you have to find it
            now vp is your
            Franz
              On 23/11/2009 at 02:51, xxxxxxxx wrote:
              Thanks alot for your replies. This is what I have now.
                   //LONG vptype;
                        if(vp->GetType() == VPPRIORITY_OBJECTGLOW)
                             vp->SetParameter(VPPRIORITY_OBJECTGLOW, TRUE,0);
              And C4D Still crashes whenever I try to load my plugin.
              Any thoughts?
                On 23/11/2009 at 05:49, xxxxxxxx wrote:
                Sorry but VPPRIORITY_OBJECTGLOW is not a videopost parameter.
                VPPRIORITY_OBJECTGLOW is not plugin type is a parameter for register plugin. what exactly you need to do 😉
                Franz
                  On 23/11/2009 at 09:12, xxxxxxxx wrote:
                  I would like to enable the Object Glow option in the render settings. Where can I find which parameter to change?
