    Help with Filename
    2 Posts 0 Posters 287 Views
      On 21/11/2009 at 08:46, xxxxxxxx wrote:
      Cinema 4D Version:   11
      So currently I insert a filename in to my shader with this method.   It works great.
                Filename earthCloudMap = GeGetPluginPath()+Filename("presets")+Filename("earth")+Filename("Cloud_Map.jpg");
                cloudData->SetFilename(BITMAPSHADER_FILENAME, earthCloudMap);
                cloudMap->Message(MSG_UPDATE);
      Now I would like to insert a file in to this shader that the user has selected via a TEXTURE description element.
      The SDK says :
      Texture elements represent a STRING (description element) entry for bitmap entries. It has an additional preview window for the selected bitmap file. Use GenerateTexturePath() to get the filename of the bitmap:
      String name = cp->GetString(PRIM_RELIEF_TEXTURE);
      Filename texture;
      GenerateTexturePath(doc->GetDocumentPath() + doc->GetDocumentName(), Filename(name), &texture;);
      I am not sure what I would put in the "Filename(name)" part o fit.. I assume that the &texture; would be the constant of the description element but I am not sure.
      Could someone please explain to me how I would do this?
      ~Shawn
        On 21/11/2009 at 09:07, xxxxxxxx wrote:
        Figured it out. Did it with ... Filename earthCloudMap = Filename(data->GetString(CLOUD_MAP,"No Image Chosen"));
