    using paths to files.
    3 Posts 0 Posters 329 Views
      On 19/11/2009 at 16:24, xxxxxxxx wrote:
      Cinema 4D Version:   11
      I use the following code to find the file Venus_Map.jpg.
      elevationData->SetFilename(BITMAPSHADER_FILENAME, Filename("Venus_Map.jpg"));
      However it will only find that file if it is in the temp directory for c4d.
      I would like it to find that file in a specific location,   namely in the plugin folder in a sub folder called presets and in another sub folder called venus.
      so the directory listing looks like this.
      How would I do that in the code I have,, I tried using the path but it won't wok.   Can someone help me?
      ~Shawn
        On 19/11/2009 at 17:47, xxxxxxxx wrote:
        Filename path = GeGetPluginPath()+Filename("presets")+Filename("venus")+Filename("Venus_Map.jpg");
        elevationData->SetFilename(BITMAPSHADER_FILENAME, path);
          On 19/11/2009 at 19:30, xxxxxxxx wrote:
          Thanks a million Robert.
          PMing you with a question.. 🙂
