    Inserting an image into the alpha channel
    7 Posts 0 Posters 679 Views
      On 17/11/2009 at 15:54, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Hello again,
      I am trying to insert in image in to the alpha channel of a material that my plugin created.
      Here's the code I am attempting to use which is not working.
      PluginShader* cloudMap = PluginShader::Alloc(Xbitmap);
      if (!cloudMap)
         return FALSE;
                atmosphereMat->GetDataInstance()->SetLink(MATERIAL_ALPHA_SHADER, cloudMap);
      cloudMap->SetParameter(BITMAPSHADER_FILENAME,"..\presets\earthCloud_Map.jpg",0);
      cloudsMat->InsertShader(cloudMap, NULL);
      Could someone help me figure out how to insert an image into the alpha channel?
      ~Shawn
        On 17/11/2009 at 16:25, xxxxxxxx wrote:
        Relative paths like that won't work. It needs to be either a filename (local to the document file) or a full path. Here are two functions that I use to set and clear the Texture link of a channel using an image. Note that this also sets the related values - you can ignore these if only interested in setting the image file. Also note that this is for a standard Material and not for a shader attached to a Material. Finally, don't forget to do a mat->Update(TRUE, TRUE) after changing all of the material's settings.
        // Set Material's Channel Texture Image and other
        void PoserMaterial::SetChannelTexture(BaseChannel* bchan, ChannelSampling* samp, const String& map, LONG mix, LONG strength)
             if (!bchan)          return;
             BaseContainer     bdata;
             Filename          mapFN = Filename(map);
             bdata.SetFilename(BASECHANNEL_SUGGESTEDFOLDER, mapFN.GetDirectory());
             bchan->SetData(bdata);
             bdata.SetString(BASECHANNEL_TEXTURE, mapFN.GetFileString());
             if (samp->use)
                  bdata.SetLong(BASECHANNEL_INTERPOLATION, samp->sampling);
                  bdata.SetReal(BASECHANNEL_BLUR_OFFSET, samp->blurOffset*0.1f);
                  Real     scale = 1.0f + (Abs(samp->blurScale) * 2.0f);
                  if (samp->blurScale < 0.0f) scale = 1.0f / scale;
                  bdata.SetReal(BASECHANNEL_BLUR_STRENGTH, scale);
             else
                  bdata.SetLong(BASECHANNEL_INTERPOLATION, BITMAPSHADER_INTERPOLATION_ALIAS1);
             if (mix)          mat->SetParameter(DescID(mix), GeData(MATERIAL_TEXTUREMIXING_MULTIPLY), DESCFLAGS_DONTCHECKMINMAX);
             if (strength)     mat->SetParameter(DescID(strength), GeData(1.0f), DESCFLAGS_DONTCHECKMINMAX);
        // Unset Material's Channel Texture Image
        void PoserMaterial::UnsetChannelTexture(BaseChannel* bchan, LONG mix, LONG strength)
             if (!bchan)          return;
             bdata.SetFilename(BASECHANNEL_SUGGESTEDFOLDER, Filename());
             bdata.SetString(BASECHANNEL_TEXTURE, "");
             if (mix)          mat->SetParameter(DescID(mix), GeData(MATERIAL_TEXTUREMIXING_NORMAL), DESCFLAGS_DONTCHECKMINMAX);
          On 17/11/2009 at 16:45, xxxxxxxx wrote:
          so is this the part that sets the filename?
          so would I then do this?
          cloudMap->SetParameter(BITMAPSHADER_FILENAME,mapFN,0);
          of course I would change the name to meet my own needs but you get teh idea..
          ~Shawn
            On 18/11/2009 at 04:03, xxxxxxxx wrote:
            The recommended way is to insert the Bitmap shader into the material and then set the texture link. The use of BaseChannels is not recommended anymore, although still working.
            BaseMaterial *mat = NULL;
            mat = doc->GetFirstMaterial();
            if(!mat) return FALSE;
            BaseContainer *data = mat->GetDataInstance();
            PluginShader *shd = NULL;
            shd = PluginShader::Alloc(Xbitmap);
            if(!shd) return FALSE;
            BaseContainer *shddata = shd->GetDataInstance();
            shddata->SetFilename(BITMAPSHADER_FILENAME, Filename("3punkt.jpg")); //Set here your texture path, relative or absolute doesn't matter
            shd->Message(MSG_UPDATE);
            data->SetLink(MATERIAL_ALPHA_SHADER, shd);
            mat->InsertShader(shd, NULL);
            mat->Message(MSG_UPDATE);
            mat->Update(TRUE, TRUE);
            EventAdd();
              On 18/11/2009 at 09:36, xxxxxxxx wrote:
              Awesome. Thanks Matthias.. You are the man!
              ~Shawn
                On 18/11/2009 at 13:37, xxxxxxxx wrote:
                for a relative path for example lets say the image I want to cal is in "\presets\earth\Cloud_Map.jpg" of the plugin folder   would I type it like I did in quotes or a different way?
                ~Shawn
                  On 18/11/2009 at 13:43, xxxxxxxx wrote:
                  nevermind..   I just used "Cloud_Map.jpg" and it worked fine. Thanks again!
                  ~Shawn
