    Fresnel Shader in the Color Channel
    4 Posts 0 Posters 439 Views
      On 13/11/2009 at 15:37, xxxxxxxx wrote:
      Cinema 4D Version:   11
      So I have created materials and objects in the plugin that I am working on.   I would like to add the fresnel shader to the COLOR channel and change the colors within that fresnel shader.   Can someone explain to me how this is done?
      I have been using :
      SetParameter() to set the Color Channel's parameters but the parameter for the color channel that houses the fresnel shader is...
      SetParameter(MATERIAL_COLOR_SHADER,?,NULL);
      I am not sure what to put for the ? argument..   or if this is even the correct course of action.
      Please any help would be greatly appreciated.
      ~Shawn
        On 17/11/2009 at 05:29, xxxxxxxx wrote:
        I solved this problem with :
                  atmosphereMat->InsertShader(fresnelColor, NULL);
                  atmosphereMat->InsertShader(fresnelTrans, NULL);
                  atmosphereMat->GetDataInstance()->SetLink(MATERIAL_COLOR_SHADER, fresnelColor);
                  atmosphereMat->GetDataInstance()->SetLink(MATERIAL_TRANSPARENCY_SHADER, fresnelTrans);
                  fresnelColor->SetParameter(SLA_FRESNEL_GRADIENT,ATMOSPHERIC_COLOR, 0);
                  fresnelTrans->SetParameter(SLA_FRESNEL_GRADIENT,Vector (0,0,0), 1);
        Now I need to insert color knots into the gradient of the fresnel shader and change their color?
        Any idea how to do this?
        ~Shawn
          The Fresnel shader's colors are actually knots of a gradient. They are part of the GradientCustomGui custom GUI and can be accessed through the Gradient custom data type. Please have a look at the GradientShader.cpp SDK example.
            On 17/11/2009 at 05:31, xxxxxxxx wrote:
            Thanks Matthias, I will look into that
            ~Shawn
