    Setting a link in a link field?
    2 Posts 0 Posters 218 Views
      On 08/11/2009 at 05:46, xxxxxxxx wrote:
      Cinema 4D Version:   10/11
      some time ago, I published the Vray Proxy Creator, which worked quite well. But suddenly, the plugin does not register anymore and throws an error instead:
      // 1. Create MeshExporter Tag
      var ExpTag = AllocTag(VRAY_EXPORTERTAG_ID);     // Create Vray MeshExporter Tag
      doc->AddUndo(UNDO_TAG_NEW, ExpTag);             // Add Undo
      op->InsertTag(ExpTag);                          // Attach tag to original object
      // 2. Create VrayProxy object
      var PrxObj = AllocObject(VRAY_PROXYOBJECT_ID); // Create VrayProxy object
      PrxObj#VRAYPROXY_LINK = ExpTag;                 // Link tag into object
      The message in the C4D console points out a syntax error in the last line of the above shown code. Why? It always worked, what has happened?
      Thanks for any tipps!
      Edit: The complete source code is shown and also available for download in the german C4D Wiki: http://wiki.c4d-jack.de/wiki/VrayProxy_Creator_(Coffee-Plugin)
      Greetings,
      Jack
        On 08/11/2009 at 05:54, xxxxxxxx wrote:
        I just noticed that it works again, if I replace the "VRAYPROXY_LINK" with the actual ID number.
        But still, I wonder why it has worked before, and what could possibly have changed within Coffee.
        Jack
