    I cant read C4DR11SDK...chm files
    12 Posts 0 Posters 1.3k Views
      On 07/11/2009 at 10:03, xxxxxxxx wrote:
      save the file to a local drive.
        On 07/11/2009 at 10:53, xxxxxxxx wrote:
        As I understood it that´s what he did but there is a permission problem with the files (maybe only on XP, haven´t tried on Win7 yet).
          On 10/11/2009 at 01:58, xxxxxxxx wrote:
          Yes, I saved it on local drive, and I cant open it.
          Right mouse click on the downloaded doc and then on the bottom of the appearing dialog there should be a message saying something like "the file has been created on a different computer and may be protected" or similar and there should be a button next to the text saying "approve" or something similar. Click on that button and that should make it work.
          Nothing like that.
          Thank you any way.
            Nothing like that.
            Thank you any way.
            You cannot open it? I thought it was simply empty?
            You do know that you have to click the "Properties" entry in the Right mouse click popup menu to get to the according dialog don´t you? Of course that buttons and infos are NOT listed in the right mouse click popup.
              Sry. It is empty.
              You do know that you have to click the "Properties" entry ...
              ofc I know that 🙂
                ofc I know that 🙂
                🙂 And the appearing dialog has nothing unusual? Do yu have a screenshot of the properties dialog?
                  On 11/11/2009 at 06:30, xxxxxxxx wrote:
                  Just belive me, properties dialog have nothing unusual, (except russian words)
                  If you are thinking Im so stupid, why do you try to help me in plugin writing? 🙂
                  any way ty a lot for trying
                    On 11/11/2009 at 06:56, xxxxxxxx wrote:
                    Hello Anton
                    Привет Антон
                    У меня все нормально с открытием chm-файлов(winXP 32sp3/64) ... Проблема может быть с браузером по умолчанию?
                    English:
                    I have normal behavior of chm reading or re-opening of it at winxp 32sp3/64... maybe problem in default browser(html)?
                      On 11/11/2009 at 13:54, xxxxxxxx wrote:
                      Unfortunately changing default browser does not help.
                        On 24/11/2009 at 06:43, xxxxxxxx wrote:
                        I had the same problem! I solved simply downloading the file using "DownThemall" a free pluguin for FIREFOX!?!
