    Cloner Object in script?
    4 Posts 0 Posters 572 Views
      On 30/09/2009 at 10:44, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      I created a small script that uses the Cloner object.
      Since the command AllocObject does not allows to add a Cloner object, I create it using CallCommand
      Then I try to change the parameters of Cloner object, but my script is FAIL and Console wrote me:
      *** [FAIL] Line Cloner test script '9: Invalid identifier for the object description ***
      I understand that there is no update object attributes Cloner.
      I tested this script in 10.5, 11 and 11.5 versions
      in 10.5 works fine
      in 11 and 11,5 - FAIL
      How can I solve this problem?
      Andrey
      > <code>
      > var obj = doc->GetActiveObject();
      >     obj->SetName("baseobject"); // Rename for searching
      > var nobj = doc->FindObject("baseobject"); // Find rename baseobject
      > CallCommand(1018544); // create Cloner Object
      > var clone = doc->GetFirstObject(); // Select Cloner
      >     clone#ID_MG_MOTIONGENERATOR_MODE = 0; // Set mode - object
      >     clone#MG_OBJECT_LINK = nobj;   // Set Link - rename base object
      >     clone#MG_POLY_MODE_=3; // Set object mode - surface
      >     clone#MG_POLYSURFACE_COUNT = 20; // Set Count
      >     clone->SetName("myclone"); // Rename for searchig
      >     clone->Message(MSG_UPDATE);
      >     var mclone = doc->FindObject("myclone");
      >     var sph = AllocObject(OSphere);
      >     doc->InsertObject(sph,mclone,null); // Insert new sphere in the cloner object
      >     sph#PRIM_SPHERE_RAD = 10;
      >     sph#PRIM_SPHERE_SUB = 12;
      > </code>
      p.s. Sorry for my English. ... and this is my first post on this forum.
        On 06/10/2009 at 02:23, xxxxxxxx wrote:
        I can confirm this. I will post it as bug.
          On 07/10/2009 at 00:44, xxxxxxxx wrote:
          You have to access the cloner object's container directly to set the object link.
          > \> var bc = cloner->GetContainer(); \> \> bc->SetData(ID_MG_MOTIONGENERATOR_MODE,ID_MG_MOTIONGENERATOR_MODE_OBJECT); \> bc->SetData(MG_OBJECT_LINK,myobject); \> \> cloner->SetContainer(bc); \>
            On 07/10/2009 at 11:32, xxxxxxxx wrote:
            Many thanks for response Matthias.
            My script work fine!
            ______________
            Best Regards.
            Andrey
