    Linking issues on Mac OSX 10.5 x86_64
    4 Posts 0 Posters 387 Views
      On 25/09/2009 at 17:38, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hello All,
      I'm running into linking issues against the sdk static library when building a GvOperatorData plugin in x86_64 mode. This plugin builds perfectly in i386 mode.
      Here is the errors I'm getting:
      Undefined symbols:
      "GvOperatorData::BodyMessage(GvNode*, GvNodeGUI*, long, long, long, long, BaseContainer const&)", referenced from:
            vtable for GvBcdCamerain GvBcdCameraNode.os
      "NodeData::IsInstanceOf(GeListNode const*, long) const", referenced from:
      "GvOperatorData::GetErrorString(GvNode*, long)", referenced from:
      "GvOperatorData::GetDescID(GvNode*, GvPortIO, long)", referenced from:
      "GvOperatorData::iGetPortDescription(GvNode*, GvPortIO, long, GvPortDescription* )", referenced from:
      "FindCustomDataTypePlugin(long)", referenced from:
            GvBcdCamera::GetPortGeData(GvNode*, GvPort*, GvRun*, GeData&)    in GvBcdCameraNode.os
      "GvOperatorData::GetDEnabling(GeListNode*, DescID const&, GeData&, long, BaseContainer const* )", referenced from:
      "GvOperatorData::GetBodySize(GvNode*, long*, long* )", referenced from:
      "GvRegisterOperatorPlugin(long, String const&, long, NodeData* (* )(), String const&, long, long, long, long, BaseBitmap* )", referenced from:
            RegisterGVBcdCamera()     in GvBcdCameraNode.os
      "GvOperatorData::OperatorMenuCommand(GvNode*, long, long, long)", referenced from:
      "PluginMessage(int, void* )", referenced from:
            _c4d_main in libc4d_release.a(c4d_pmain.o)
      "NodeData::Message(GeListNode*, long, void* )", referenced from:
      "GvOperatorData::GetDParameter(GeListNode*, DescID const&, GeData&, long&)", referenced from:
      "GvOperatorData::FillPortMenu(GvNode*, BaseContainer&, long, long)", referenced from:
      "NodeData::GetBranchInfoEx(GeListNode*, BranchInfo*, long)", referenced from:
      "GvOperatorData::GetPortIcon(GvNode*, long, GvLayoutType)", referenced from:
      "GvOperatorData::FillPortsMenu(GvNode*, BaseContainer&, BaseContainer&, long, GvPortIO, long)", referenced from:
      "NodeData::CopyTo(NodeData*, GeListNode*, GeListNode*, long, AliasTrans* )", referenced from:
      "NodeData::Read(GeListNode*, HyperFile*, long)", referenced from:
      "GvOperatorData::SceneDraw(GvNode*, BaseDraw*, BaseDrawHelp*, BaseThread*, long, void*, unsigned long)", referenced from:
      "GvOperatorData::SetDParameter(GeListNode*, DescID const&, GeData const&, long&)", referenced from:
      "GvOperatorData::FillOperatorMenu(GvNode*, BaseContainer&, long)", referenced from:
      "GvOperatorData::EditorDraw(GvNode*, GvNodeGUI*, GeUserArea*, long, long, long, long)", referenced from:
      "GvOperatorData::GetDDescription(GeListNode*, Description*, long&)", referenced from:
      "NodeData::GetBranchInfo(GeListNode*, BranchInfo*, long, unsigned long)", referenced from:
      "GvOperatorData::PortMenuCommand(GvNode*, long, long, long, long)", referenced from:
      "GeLoadString(long)", referenced from:
      ld: symbol(s) not found
      The linker flags i'm using for x86_64 are the following:
      -o ./output/MyGvNode.dylib
      -m64
      -fno-common
      -flat_namespace
      -bundle
      -lm
      -lc4d_release
      The only different flag in building the i386 version is "-m32".
      BTW i renamed lib_api_release.a to libc4d_release.a. C4d gurus, could you shed some light on this?
      Wei
        On 25/09/2009 at 17:40, xxxxxxxx wrote:
        Some additional information:
        Mac OSX 15.0
        C4D R11.026 (64 bit) (Build F|15745)
        Gcc 4.0
          On 28/09/2009 at 14:50, xxxxxxxx wrote:
          Anyone?
          I'd really appreciate your help. Could anybody who's had success building 64-bit version of their plug-ins chime in?
          Thanks very much!
          Wei
            On 28/09/2009 at 15:30, xxxxxxxx wrote:
            Are you using the cinema4dsdk.xcodeproj as a template for your plugin project? You can't just use any old project settings - you want to stick with those in that project and modify carefully.
