    Create Global Matrix port
    3 Posts 0 Posters 282 Views
      On 23/09/2009 at 00:03, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Language(s) :
      I want to create a global matrix port on an object node. Currently thats my code:
      > \>             DescID cubeid = DescID(DescLevel(GV_OBJECT_OPERATOR_GLOBAL_OUT)); \>             portID =     GvCall(ot->GetOperatorData(), GetMainID)(ot, GV_PORT_OUTPUT, cubeid); \>             if(portID==NOTOK) return FALSE; \>              \>             Bool ok = ot->AddPortIsOK(GV_PORT_INPUT, portID); \>             if(ok==FALSE) return FALSE; \>
      I use the constans of the file: gvoperator.h
      But nothing happens. Is this the correct way?
      Thanks for your help.
      Cheers, Shawni
        On 29/09/2009 at 02:53, xxxxxxxx wrote:
        You just pass the port ID to AddPortIsOK and AddPort.
        Example:
        > \> if (node->AddPortIsOK(GV_PORT_INPUT, GV_OBJECT_OPERATOR_GLOBAL_IN)) \> { \>      GvPort \*port = NULL; \>      port = node->AddPort(GV_PORT_INPUT, GV_OBJECT_OPERATOR_GLOBAL_IN, GV_PORT_FLAG_IS_VISIBLE, TRUE); \> \>      if (port) \>      { \>           //do something \>      } \> } \>
          On 29/09/2009 at 03:46, xxxxxxxx wrote:
          Hi Matthias,
          yes, this works fine (I tested yesterday). The problem is, that AddPort just takes a LONG value so a real DescID element is not possible ( to create a Position.X port). So I tried to merge these cases. GvCall just returns 0 on a global matrix, but works fine when I just pass a DescID element which points to a Subchannel Port (like Vector.x)
          > <code>
          > #define GvCall(op,fnc) (((GvOperatorData* )op)->*((OPERATORPLUGIN* )C4DOS.Bl->RetrieveTableX((NodeData* )op,1))->fnc)
          > //I found this definition on plugincafe
          > /* .code.*/
          > DescID passedID = PyObject2DescID(id, ok); //convert my list [id, id, id] to a DescID element
          > switch(io)
          >     case GV_PORT_INPUT:
          >         LONG portID = GvCall(ot->GetOperatorData(), GetMainID)(ot, GV_PORT_INPUT, passedID);
          >         if(portID==0) { // is not 0 if I pass a Vector.x Port DescID   [POSITION, POSITION_X]
          >             portID = passedID[0].id; //otherwise just pass the ID, it might work 🙂
          >         if(ok==FALSE) return None;
          >         GvPort *port = ot->AddPort(GV_PORT_INPUT, portID, (GvPortFlags)flag, message);
          >         break;
          > </code>
          Just subports like ports of the Math Node doesnt work yet, but this is another problem I have to check. This is just a "stupid" workaround, but it seems to work. Do you think thats still ok?
          Cheers, Sebastian
