    Strange Crashing
    10 Posts 0 Posters 870 Views
      On 07/09/2009 at 08:18, xxxxxxxx wrote:
      Cinema 4D Version:   11
      I am trying to get a command button to call a certain function. This is Tool plugin.
      Here's the code in the message() which looks for the command button to be clicked.
      \>  Bool SculptTool::Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data)
      \>  switch (type)
      \>            case MSG_DESCRIPTION_COMMAND:
      \>            DescriptionCommand *dc = (DescriptionCommand* ) t_data;
      \>            if (dc->id[0].id==COMMAND_SUBDIVIDE)
      \>                 GePrint("Subdivide Button Clicked");
      \>                 ModelingCommandData mdat;
      \>                 BaseContainer bc;
      \>                 mdat.bc = &bc;
      \>              DoCommand(mdat);
      \>       return TRUE;
      Here's the code in the DoCommand()
      \>  Bool SculptTool::DoCommand(ModelingCommandData &mdat;)
      \>  GePrint("In DoCommand");
      \>  //CODE RELATED TO THE SUBDIVISION OPTIONS/////////////////////////////////
      \>       //Define Variables
      \>      PolygonObject *objPoly = ToPoly(mdat.doc->GetActiveObject());
      \>       if (!objPoly) return FALSE;
      \>       //Determine Attributes
      \>       if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE)) //If HyperNURBS is checked
      \>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE); //Set HyperNURBS subdivision
      \>       else
      \>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE); //Disable HyperNURBS subdivision
      \>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, mdat.bc->GetLong(NUM_SUBDIVISIONS)); //Set Number of Subdivisions
      \>       mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE)); //Set Maxiumum Angle
      \>       //Subdivision Command
      \>       SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
      \>       mdat.bc->SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());
      \>       return TRUE;
      \>  //END SUBDIVISION OPTIONS/////////////////////////////////////////////////
      For some reason, C4D crashes whenever I click the command button. I get the "GePrint" message that says "InCommand" so I know the problem is happening in the DoCommand(). Or at least I think that's where it's happening.
      Does anyone have any ideas as to what would be causing C4D to crash?
      ~Shawn
        On 07/09/2009 at 09:09, xxxxxxxx wrote:
        This line probably points to an empty document pointer.
        PolygonObject *objPoly = ToPoly(mdat.doc- >GetActiveObject());
        Always check for valid pointers!
        Fill the ModelingCommandData with the current document.
          On 07/09/2009 at 09:18, xxxxxxxx wrote:
          would I do that with something like this?
          BaseDocument* doc;
               mdat.doc = doc;
            On 07/09/2009 at 09:27, xxxxxxxx wrote:
            No, in this case you would simply pass the doc from the Message function.
            > \> Bool SculptTool::Message(BaseDocument\* doc, BaseContainer & data, LONG type, void\* t_data) \> { \>      ... \>       \>      mdat.doc = doc; \>       \>      ... \> } \>
              On 07/09/2009 at 09:32, xxxxxxxx wrote:
              Awesome. Okay now it doesn't crash, but the problem now is.. it doesn't do anything. . LOL I still get the "In DoCOmmand" message, so it is doing the command. but none of the code in DoCommand() is executing?
              Any thoughts there?
              Thanks a lot Matthias.
              ~Shawn
                On 07/09/2009 at 10:36, xxxxxxxx wrote:
                Any thoughts on why it's not doing anything?
                ~Shawn
                  On 07/09/2009 at 11:45, xxxxxxxx wrote:
                  Since SendModelingCommand() works on objects, you MUST specify the object in ModelingCommandData:
                  mdat->op = objPoly;
                  Otherwise it doesn't do anything, yes. 🙂
                    On 07/09/2009 at 12:55, xxxxxxxx wrote:
                    okay I did that and it still does nothing. 😞 Any thoughts? I added
                    mdat->op = objPoly;
                    Here's new code for DoCommand()
                    \>       mdat.op = objPoly;
                    \>       else
                    \>       mdat.bc->SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());//Shows the current polygon count
                    \>       return TRUE;
                    \>       GePrint("End Of DoCommand");
                      On 07/09/2009 at 13:57, xxxxxxxx wrote:
                      Have you checked the values being set in mdat, especially MDATA_SUBDIVIDE_SUB? This must be >0. mdat.mode should be MODIFY_ALL.
                        On 07/09/2009 at 14:36, xxxxxxxx wrote:
                        okay nothing happens when I click the button. But something very weird happens when I click the button and then resize the viewport frame. I click the button, nothing happens, then I resize the viewport frame and suddenly the cube in my viewport subdivides. But not by the number that is in the LONG NUM_SUBDIVISIONS. I am not sure where it is getting this number from ..
                        Here's the code I have in DoCommand().
                        Thanks for your help.
                        \>       mdat.mode = MODIFY_ALL;
                        \>       else
                        \>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, mdat.bc->GetLong(NUM_SUBDIVISIONS); //Set Number of Subdivisions
                        \>       return TRUE;
                        Weird huh?
