    TranslationMaps and polygons
    1 Posts 0 Posters 135 Views
      On 07/09/2009 at 03:54, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      I am getting some results when using the TranslationMaps for polygons that I cannot explain.
      When you delete an ngon that consists of two or more polygons, the information that is passed in the translation maps is not what I would expect.
      here is a code snippet I use in the Message member of a tag plugin.
      > <code>
      \>  if (type==MSG_TRANSLATE_POLYGONS)
      \>       {     // Update the indexes as needed
      \>            BaseContainer *bc=((BaseList2D* )node)->GetDataInstance();
      \>            if (!bc)
      \>                 return false;
      \>            LONG lngI,lngJ,lngSize;
      \>            TranslationMaps *map;
      \>            map=(TranslationMaps* )data;
      \>            if (map)
      \>                 // New to old polygon mapping
      \>                 if (arrNewToOldPoly)
      \>                      GeFree(arrNewToOldPoly);
      \>                 lngSize = sizeof(LONG) * map->m_nPolygonCount;
      \>                 arrNewToOldPoly = (LONG* )GeAlloc(lngSize);
      \>                 if (!arrNewToOldPoly)
      \>                      return false;
      \>                 for (lngI=0;lngI<map->m_nPolygonCount;lngI++)
      \>                 {     if (lngI>=map->m_oPolygonCount)
      \>                      {     arrNewToOldPoly[lngI]=-1;
      \>                      else
      \>                      {     arrNewToOldPoly[lngI]=lngI;}
      \>                 for (lngJ=0;lngJ<map->m_mPolygonCount;lngJ++)
      \>                      GePrint("New To Old "+LongToString(map->m_pPolygonMap[lngJ].nIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].oIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].lFlags));
      \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_NEW))
      \>                      {     arrNewToOldPoly[map->m_pPolygonMap[lngJ].nIndex]=-1;
      \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_MOVED))
      \>                      {     if (map->m_pPolygonMap[lngJ].nIndex != -1)
      \>                           {     arrNewToOldPoly[map->m_pPolygonMap[lngJ].nIndex]=map->m_pPolygonMap[lngJ].oIndex;
      \>                 // Old to new polygon mapping
      \>                 if (arrOldTonewPoly)
      \>                      GeFree(arrOldTonewPoly);
      \>                 lngSize = sizeof(LONG) * map->m_oPolygonCount;
      \>                 arrOldTonewPoly = (LONG* )GeAlloc(lngSize);
      \>                 if (!arrOldTonewPoly)
      \>                      return false;
      \>                 for (lngI=0;lngI<map->m_oPolygonCount;lngI++)
      \>                 {     arrOldTonewPoly[lngI]=lngI;
      \>                 {     GePrint("Old To New "+LongToString(map->m_pPolygonMap[lngJ].nIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].oIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].lFlags));
      \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_DELETED))
      \>                      {     arrOldTonewPoly[map->m_pPolygonMap[lngJ].oIndex]=-1;
      \>                      {     arrOldTonewPoly[map->m_pPolygonMap[lngJ].oIndex]=map->m_pPolygonMap[lngJ].nIndex;
      > </code>
      Now if use some simple polygon objects (I started with a cube with 2 segments), and do some simple tests this is what I get:
      Delete a single polygon:
      Highest polygon index is 23, the index of the polygon that gets deleted is 7
      The polygon mapping gives this
      nIndex -1 oIndex 7 lFlags 8 (TRANSMAP_FLAG_DELETED)
      nIndex 7 oIndex 23 lFlags 4 (TRANSMAP_FLAG_MOVED)
      That makes perfect sense but if I try to delete a ngon that consists of 2 polygons things are not that clear
      Delete a ngon:
      Highest polygon index is 26, the indexes of the polygons that make up the ngon are 25 and 7
      nIndex 7 oIndex 26 lFlags 4 (TRANSMAP_FLAG_MOVED)
      nIndex -1 oIndex 28 lFlags 8 (TRANSMAP_FLAG_DELETED)
      So the mapping tells me that polygon 25 (old index) has not been changed, although it does not exist any more
      and both polygon 26 and 7 (old index) are now both polygon 7 (new index) although the original 7 has been deleted.
      Is this a bug or am I missing something?
      Nebu
