    BaseFile
    4 Posts 0 Posters 303 Views
      On 04/09/2009 at 08:17, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Hi
      I've been having trouble getting basefile to work, I've been copying the example from the sdk
      // Creates a filename that points to "foo.txt" in the plugin's directory
      var filename = GeGetRootFilename();
      filename->RemoveLast();
      filename->Add("foo.txt");
      // Creates the file and writes a string to it
      var file = new(BaseFile);
      file->Open(filename, GE_WRITE);
      file->WriteString("Hello World!");
      into the the <MyMenuPlugin::Execute(doc)> part of the "hello world 2" example along with some other code that extracts user data from each frame. The other code runs but nothing seems to happen with the new Basefile part. I also tried Matthias's
      var fn = new(Filename);
      if(!fn) return;
      if(!fn->FileSelect("Create file", TRUE)) return;
      var file = new(basefile);
      if(!file) return;
      if(!file->Open(fn, GE_WRITE, FILE_IGNOREOPEN, GE_INTEL)) return;
      if(!file->WriteString("hallo", GE_7BIT)) return;
      but I get an empty txt. file. I'm struggling to come up with something new to try.
      Any help would be much appreciated.
      Kind regards
      Conor
      I've attached the full code as well.
      var PLUGIN_ID = 910002;
      // make a dialog class
      class MyDialog : GeModalDialog
                MyDialog();
      CreateLayout();
      MyDialog::MyDialog() { super(); }
      MyDialog::CreateLayout()
           SetTitle("Hello World");
      AddStaticText(4000,BFH_FIT,0,0,"Text Exporter",BORDER_THIN_IN);
      AddDlgGroup(DR_DLGGROUP_OK|DR_DLGGROUP_CANCEL);
      // register plugin in menu
      class MyMenuPlugin : MenuPlugin
                MyMenuPlugin();
      GetID();
                GetName();
                GetHelp();
      Execute(doc);
      MyMenuPlugin::MyMenuPlugin() { super(); }
      MyMenuPlugin::GetID()        { return PLUGIN_ID; }
      MyMenuPlugin::GetName()      { return "Hello World"; }
      MyMenuPlugin::GetHelp()      { return "Demonstrates a simple modal dialog";
      var d = new(MyDialog);
      d->Open(-1,-1);
      var t = doc->GetTime();
      var sec = t->GetSecond();
      var frame =int( t->GetFrame(doc->GetFps()));
      var max_time = doc->GetMaxTime();
      var max_sec = max_time->GetSecond();
      var max_frame =(int(max_time->GetFrame(doc->GetFps())));
      var fps = doc->GetFps();
      var op = doc->FindObject("userdata");
      var arr_1 = new(array,(max_frame+1));
           var arr_2 = new(array,(max_frame+1));
           var arr_3 = new(array,(max_frame+1));
           var arr_4 = new(array,(max_frame+1));
      var userStartTime = -1;
      var userEndTime = max_frame;
      var bakeStartTime = GetActiveDocument()->GetTime(); //needed to initialize a BaseTime object
      bakeStartTime->SetFrame(userStartTime, fps);
      doc->SetTime(bakeStartTime); //set the time slider to the user's start time
      var currentFrame = GetActiveDocument()->GetTime()->GetFrame(fps);
      while(currentFrame < userEndTime)
           StopAllThreads();
      userStartTime++;
           bakeStartTime->SetFrame(userStartTime, fps); //needed to convert frame to BaseTime
           doc->SetTime(bakeStartTime);//SendPlayhead to next frame
           var redraw = DrawViews(DA_STATICBREAK);
      EventAdd(EVENT_ANIMATE);
           if(redraw == TRUE) currentFrame = GetActiveDocument()->GetTime()->GetFrame(fps);
      arr_1[frame] = (op#ID_USERDATA:1);
           arr_2[frame] = (op#ID_USERDATA:2);
           arr_3[frame] = (op#ID_USERDATA:3);
           arr_4[frame] = (op#ID_USERDATA:4);
      if(!fn) return;
      if(!file) return;
      fn->SetSuffix("txt");
      var i = 0;
      for(i=0;i <=userEndTime;i++)
      println(i);
      println(arr_1 _);
      println(arr_2 _);
      println(arr_3 _);
      println(arr_4 _);
      if(!file- >WriteString("hallo", GE_7BIT)) return;
      file->Close();
      println("Ready");
           Register(MyMenuPlugin);
        On 06/09/2009 at 02:06, xxxxxxxx wrote:
        Hi I've found the problem (I should have left return off "if(!file->WriteString("hallo", GE_7BIT)) return;" It's working fine now. Is there a newline function in that can be used with WriteString?
        Regards Conor
          On 06/09/2009 at 11:26, xxxxxxxx wrote:
          C/C++/Java/COFFEE/etc.: newline '\n' character. This type of notation (with the \) is called an 'escape character' or 'escape sequence'. With it you can do things like (tab), \\ (actually print \), \0value (an ASCII/UniCode value, number). Do a Google search for 'escape sequence' and you'll get many links to lists of and information on them. 🙂
          file->WriteString("Hallo\n", GE_7BIT);
            On 06/09/2009 at 11:40, xxxxxxxx wrote:
            Thanks very much Robert, that's working great now.
            Cheers Conor
