    GetAndCheckHierarchyClone() Problem?
    3 Posts 0 Posters 356 Views
      On 01/09/2009 at 09:47, xxxxxxxx wrote:
      Cinema 4D Version:   9.1+
      Howdy,
      I have a problem with my input object:
      It seems that the GetAndCheckHierarchyClone() function can only handle one type of flag from the list of flags for a given hierarchy:
      > Quote: __
      > HCLONE_ASIS - Objects unchanged. (Used by e.g. ArrayObject.)
      > HCLONE_ASPOLY - Objects cloned as polygons. (Used by e.g. HyperNURBS.)
      > HCLONE_ASLINE - Objects cloned as line objects.
      > HCLONE_ASSPLINE - Objects cloned as splines.
      I found this thread:
      Search thread
      ... that shows how to handle multiple flags, but it doesn't work if the hierarchy in question is a mixture of different object types.
      If the hierarchy is like this:
      Plugin Object (input)
      -Sphere Primitive
      --Instance (cube)
      --Spline Primitive
      ... then the Spline Primitive is ignored
      -Spline Primitive
      --Sphere Primitive
      --Instance (Cube)
      ... then both the Sphere Primitive and the Instance are ignored.
      How can I get it to handle both flags when both types of objects are in the same hierarchy?
      Adios,
      Cactus Dan
        On 04/09/2009 at 02:11, xxxxxxxx wrote:
        Can you please post some code.
        This seems to work for me:
        > \> BaseObject \*res = NULL, \*orig = NULL; \>       \> orig = op->GetDown(); \> \> // return if no input object is available \> if (!orig) return NULL; \> \> // request polygonized input \> hh->AddVFlags(VFLAG_POLYGONAL); \> \> Bool dirty = FALSE; \> \> // generate polygonalized clone of input object \> res = op->GetAndCheckHierarchyClone(hh,orig,HCLONE_ASPOLY|HCLONE_ASSPLINE,&dirty;,NULL,TRUE); \>
          On 04/09/2009 at 09:12, xxxxxxxx wrote:
          Howdy,
          Thanks for the reply, but I found the solution to my problem in your sticky thread "Poly meshes and GetVirtualObjects()". Probably should've looked at that thread in the first place. ;o)
          Adios,
          Cactus Dan
