    set frame
    6 Posts 0 Posters 571 Views
      On 24/08/2009 at 06:35, xxxxxxxx wrote:
      Cinema 4D Version:
      Platform:      Mac OSX  ;
      Hi I know that this is probably very simple, but I'm afraid I'm not getting it. I'm trying to write a coffee tag pluggin and to fill an array. I want to use a loop to scroll through the frames and fill the user data info for each frame.
      I've tried:
      var i = 0;
      for (i = 0; i < max_frame; i = i + 1) {
      BaseTime (i,25);
      doc->SetTime();
      print (frame);
                          print (",");
                          print( arr_number[frame]);
                          println(" "); }
      but I'm not having any joy. Any help would be greatly appreciated.
      Regards Conor
        On 24/08/2009 at 06:49, xxxxxxxx wrote:
        Do something like this:
        > \> var i = 0; \> \> for (i = 0; i < 50; i++) \> { \>      var time = new(BaseTime); \>      time->SetFrame(i,25.0); \>      doc->SetTime(time); \> } \>
          On 24/08/2009 at 07:22, xxxxxxxx wrote:
          Thanks Matthias, I've tried this but its still not doing what I expected, instead of printing each frame and its user data, it prints out the current frame and its user date ,again and again, for the length of the loop.
          Is there a simpler way to fill an array ( made up of each frame and its user data)?
            On 24/08/2009 at 07:29, xxxxxxxx wrote:
            If I understand you correctly you want to fill an array with user data for each frame. If so then i think a COFFEE tag is not the best way to do it. Have you looked into writing a COFFEE script or MenuPlugin instead?
              On 24/08/2009 at 07:32, xxxxxxxx wrote:
              No. I'll start reading up on this now.
              Cheers Conor
                On 24/08/2009 at 07:37, xxxxxxxx wrote:
                The thing is a COFFEE tag is an expression which is called for eachframe and every change you make. A script or MenuPlugin is called just once by the user.
                Btw. if you use SetTime() you also have to call AnimateDocument() to actually animate the document.
