    Visual Aid
    46 Posts 0 Posters 38.4k Views
      On 23/08/2009 at 22:46, xxxxxxxx wrote:
      okay this is the code I have .
      \>  LONG TrueSymmetry::Draw(PluginTag* tag, BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt,LONG flags)
      \>       if (tag->GetDataInstance()->GetBool(SHOW_PLANE)) // draw
      \>            //Vector p[3] = { Vector(0,0,0),Vector(100,0,0),Vector(50,100,0)};
      \>            //Vector f[3] = { Vector(1,0,0),Vector(1,0,0),Vector(1,0,0)};
      \>            //bd->Polygon3D(p,f,TRUE);
      \>            GePrint ("It's Checked");
      \>       else
      \>            GePrint ("Not Checked");
      \>       return TRUE;
      At this point I'm just looking for a message to come back and tell me that the box was checked. But nothing is showing up.
      Do you see anything wrong?
      ~Shawn
        On 24/08/2009 at 06:21, xxxxxxxx wrote:
        Any thoughts about this?
          On 24/08/2009 at 06:31, xxxxxxxx wrote:
          The code looks ok to me. There must be somewhere else an error I guees.
            On 24/08/2009 at 07:27, xxxxxxxx wrote:
            Can you think of anything that would prevent GePrint () from printing to the console? It seems like it's not recognizing that the checkbox was checked.
              On 24/08/2009 at 07:32, xxxxxxxx wrote:
              Without any additional code it is hard to say. Maybe the description resource for the checkbox is wrong.
                On 24/08/2009 at 07:39, xxxxxxxx wrote:
                Here's the reference from the .h file
                SHOW_PLANE = 1005,
                Here's the reference from the .res file
                BOOL SHOW_PLANE {ANIM OFF;}
                Here it is from the .str file
                SHOW_PLANE "Show Symmetry Plane";
                  On 24/08/2009 at 07:44, xxxxxxxx wrote:
                  I can send you more code if you think it would be helpful.
                  ~Shawn
                    On 24/08/2009 at 07:46, xxxxxxxx wrote:
                    > ~Shawn
                    Please do, because the description resource seems to be ok.
                    Btw. is the Draw() method called at all?
                      On 24/08/2009 at 07:52, xxxxxxxx wrote:
                      Here is the code up to this function.
                      \>  // TrueSymmetry
                      \>  #include "c4d.h"
                      \>  #include "c4d_symbols.h"
                      \>  #include "ttruesymmetry.h"
                      \>  #include "truesymmetry.h"
                      \>  #include "lib_description.h"
                      \>  #include "customgui_priority.h"
                      \>  const Real DELTA=0.001f;
                      \>  class TrueSymmetry : public TagData
                      \>       Bool blnMessages;
                      \>       Bool blnSymmetryActive;
                      \>       Bool blnSymmetryDirty;
                      \>       Bool blnTest;
                      \>       Bool IsSymmetrical(BaseObject* obj , BaseContainer* data);
                      \>       Bool InitSymmetryPoints(BaseObject* obj,BaseContainer* data);
                      \>       Bool InitSymmetryPolygons(BaseObject* obj,BaseContainer* data);
                      \>       Bool IsPartner(const Vector * arrPoints, LONG lngI, LONG lngJ, LONG lngSymPlane);
                      \>       Bool OnSymmetryPlane(const Vector * arrPoints, LONG lngI, LONG lngSymPlane);
                      \>       Bool PointOnEditableSide(const Vector * arrPoints, LONG lngI, LONG lngSymPlane, LONG lngMirroredSide,bool blnIncNul);
                      \>       Bool PolyOnEditableSide(const Vector * arrPoints, const CPolygon * arrPolygons,LONG lngI, LONG lngSymPlane, LONG lngMirroredSide);
                      \>       Bool PolygonStillExists(const CPolygon * arrPolygons, LONG lngOldPoly);
                      \>       LONG FindLastKnowPolyPartner(const CPolygon * arrPolygons,LONG lngOldPoly);
                      \>       LONG FindPolyPartner(const CPolygon * arrPolygons, LONG lngPolygonCount,LONG lngPoly);
                      \>       Bool ResetPointsOnSymPlane(PolygonObject* objPoly,BaseContainer* data);
                      \>       Bool UpdateSymmetryPositions(PolygonObject* objPoly,BaseContainer* data);
                      \>       Bool CreateSymmetry(BaseObject* obj ,BaseContainer* data);
                      \>       Bool ReInitSymmetry(BaseObject* obj,BaseContainer* data);
                      \>       Vector GetVirtualPartnerPos( Vector * arrPoints, LONG lngI, LONG lngSymPlane);
                      \>       CPolygon GetVirtualPartnerPolygon(CPolygon * arrPolygons, LONG lngPoly);
                      \>       LONG * arrPartners;
                      \>       Vector * arrLastKnownPos;
                      \>       CPolygon* arrLastKnownPolygons;
                      \>       LONG lngLastKnownPointCount;
                      \>       LONG lngLastKnownPolygonCount;
                      \>       public:
                      \>            virtual Bool Init(GeListNode *node);
                      \>            virtual void Free(GeListNode *node);
                      \>            virtual Bool GetDDescription(GeListNode *node, Description *description,LONG &flags;);
                      \>            virtual Bool Message(GeListNode *node, LONG type, void *data);
                      \>            virtual LONG Execute(PluginTag* tag, BaseDocument* doc, BaseObject* op, BaseThread* bt, LONG priority, LONG flags);
                      \>            virtual Bool GetDEnabling(GeListNode *node, const DescID &id;,GeData &t;_data,LONG flags,const BaseContainer *itemdesc);
                      \>            //FOR SHOWING SYMMETRY PLANE
                      \>            virtual LONG Draw(PluginTag* tag, BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt,LONG flags);
                      \>            static NodeData *Alloc(void) { return gNew TrueSymmetry; }
                      \>  //FOR DRAWING THE SYMMETRY PLANE
                      \>            Vector p[4] = { Vector(-100,0,0),Vector(100,0,0),Vector(-100,100,0),Vector(100,100,0)};
                      \>            Vector f[3] = { Vector(1,0,0),Vector(1,0,0),Vector(1,0,0)};
                      \>            bd->Polygon3D(p,f,TRUE);
                      \>       else
                      \>            return DRAW_HANDLES|DRAW_AXIS;
                      If this does not show the problem I can email you the whole contents of the .cpp file if you PM me your email.
                      Thanks so much Matthias for taking the time to help me out.
                      ~Shawn
                        On 24/08/2009 at 07:58, xxxxxxxx wrote:
                        I just realize that your Draw function has a wrong declaration. For TagData plugins it looks like this
                        virtual Bool Draw(PluginTag *tag, BaseObject *op, BaseDraw *bd, BaseDrawHelp *bh)
                        Your Draw() method is probably never called.
                          On 24/08/2009 at 08:06, xxxxxxxx wrote:
                          There it is.... That was the solution.. Thanks alot Matthias. You really help me out here.
                          ~Shawn
                            On 24/08/2009 at 08:24, xxxxxxxx wrote:
                            how do I remove the polygon after I have drawn it? I am able to draw a polygon on the symmetry plane now but I want it to go away after they uncheck the bool.
                            Thanks in advance,
                            ~Shawn
                              On 24/08/2009 at 09:31, xxxxxxxx wrote:
                              Figured it out. Thanks,
                              ~Shawn
                                On 24/08/2009 at 10:41, xxxxxxxx wrote:
                                Anyone know how i could make the polygon I create appear somewhat translucent?
                                ~Shawn
                                  On 24/08/2009 at 10:56, xxxxxxxx wrote:
                                  Figure this out too.. LOL.. guess I'll stop asking until I really try to figure it out. HAHA..   Thanks everyone.
                                  This was accomplished using SetTransparency ()
                                  ~Shawn
                                    On 24/08/2009 at 10:57, xxxxxxxx wrote:
                                    BaseDraw::SetTransparency(LONG trans) with negative values for trans.
                                      On 24/08/2009 at 11:50, xxxxxxxx wrote:
                                      Well , I was hoping I wouldn't have to ask again. LOL but can someone point me in the right direction on how to be able to take the color selected from a COLOR selector in the attributes manager and turning that into the color values for the polygon3D()..
                                      ~Shawn
                                        On 24/08/2009 at 11:58, xxxxxxxx wrote:
                                        Vector color = bc->GetVector(YOUR_DESC_FOR_THE_COLOR);
                                          On 24/08/2009 at 12:00, xxxxxxxx wrote:
                                          Thanks Robert, As always. Top Notch!
                                          ~Shawn
                                            On 24/08/2009 at 21:00, xxxxxxxx wrote:
                                            Finally, the last step I need to do is to get the polygon that I have created, aligned, resized, and changed the color, to stay locked to the object on which the tag is.
                                            For example, this portion of my plugin creates a visible symmetry plane on an object. I would like this new polygon to stay attached to the object no matter where it is moved around in 3d space. Can someone point me in the right direction on how to accomplish this?
                                            ~Shawn
