    check if time has changed
    5 Posts 0 Posters 393 Views
      On 21/08/2009 at 02:47, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:    Mac  ;
      Hi, please excuse the extreme beginner question, but I am trying to make a pluggin that updates only when the animation is playing. I've tried this:-
      main(doc,op)
      var number,on_off,coffee_tag,store_t,sec,last_time;
      doc->SetFps( 25 );
      coffee_tag=op->GetFirstTag();
      while(coffee_tag)
           {if(instanceof(coffee_tag, CoffeeExpressionTag)) break;
           coffee_tag=coffee_tag->GetNext();
      if(!coffee_tag) return;
      if(!(coffee_tag#ID_USERDATA:2)) return;
      // GET TIME
      var t = doc->GetTime();
      var sec = t->GetSecond();
      if (sec == last_time)return;
      number=coffee_tag#ID_USERDATA:1;
      println (number);
      last_time == sec;
      but no joy, any pointers would be greatly appreciated.
      Many regards Conor
        On 21/08/2009 at 02:57, xxxxxxxx wrote:
        What kind of plugin? An Expression Tag? We need some more information. The code you show here looks more like code from a Coffee Tag or Coffee Node.
        Generally, store values like last_time OUTSIDE the main function.
        Greetings,
        Jack
          On 21/08/2009 at 03:11, xxxxxxxx wrote:
          Hi Jack
          it's a Coffee tag, eventually I hope to make a pluggin that saves the user data from my coffee tag to a text document for each frame of my animation, but as you can see it is baby steps at the moment.
          If I want to store last_time outside the main function, should this go at the end of the script?
            On 21/08/2009 at 03:48, xxxxxxxx wrote:
            With a COFFEE tag you would do something like this:
            > \> var lasttime; \> \> main(doc,op) \> { \>      if (!lasttime) lasttime = doc->GetTime(); //initialize lasttime \> \>      var time = doc->GetTime(); //current document time \> \>      if (time->IsEQ(lasttime)) \>           println("equal"); //times are equal \>      else \>           println("not equal"); //times are not equal, animation is playing \> \>      lasttime = doc->GetTime(); //write current time back to lasttime \> } \>
            lasttime is a global variable, outside of main(doc,op).
            In a plugin you can store the time in a local class variable. Rule of thumb, avoid global variables.
              On 21/08/2009 at 03:52, xxxxxxxx wrote:
              Matthias you legend, thank you very much.
              Conor
