    Accessing Render Data with COFFEE
    9 Posts 0 Posters 866 Views
      On 19/08/2009 at 12:30, xxxxxxxx wrote:
      Cinema 4D Version:   11.x
      Is it possible to access the render data of a document in order to check what Effects were added? I know I can access the render data base container. What I don't know is how to check for the list of Effects that may have been added.
      I only need to know their IDs. Is this info accessible somehow?
        On 20/08/2009 at 00:16, xxxxxxxx wrote:
        you can get it with GetActiveRenderData()->GetFirstVideoPost() and cycle through with GetNext(). GetType() should get you the ID.
          On 20/08/2009 at 00:49, xxxxxxxx wrote:
          ah, sorry. didn't realize you needed it for coffee
            On 20/08/2009 at 05:01, xxxxxxxx wrote:
            No posteffect acces with coffee.
            very bad limitation
            sorry
            Franz
              On 20/08/2009 at 06:59, xxxxxxxx wrote:
              That is, in fact, a very bad limitation.
              It should be easy to implement, I believe.
              I wonder why doesn't COFFEE gets a facelift?!
              Rui Batista
                On 20/08/2009 at 07:09, xxxxxxxx wrote:
                hello Rui,
                Sadly this limitation is main reason because i have switched to c++.
                i sugest you to make the jump 😉
                al the best
                Franz
                  On 20/08/2009 at 08:02, xxxxxxxx wrote:
                  or jump to another lan... ok, I am quiet 🙂
                    On 20/08/2009 at 08:04, xxxxxxxx wrote:
                    shure... python can be the solution 🙂 very good solution
                    Franz
                      On 20/08/2009 at 08:06, xxxxxxxx wrote:
