    Howto create layerobject
    7 Posts 0 Posters 851 Views
      On 22/07/2009 at 14:39, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Howto create LayerObject?
      First wrong
      > BaseObject\* lay = BaseObject::Alloc(Olayer); \> (!lay) return FALSE;     // return null pointer \> lay->SetName(LayNameString); \> doc->InsertObject(lay,NULL,NULL,FALSE);
      Second wrong
      > LayerObject\* lay = LayerObject::Alloc(); \> (!lay) return FALSE;     // Good \> lay->SetName(LayNameString); \> doc->InsertObject((BaseObject\* )lay,NULL,NULL,FALSE);//Crash
      Please help.
        On 22/07/2009 at 14:56, xxxxxxxx wrote:
        Hi dinnye,
        The LayerObject has nothing to do with BaseObject. See class hierarchy.
        What you want to do?
        Bye, Sebastian
          On 22/07/2009 at 15:12, xxxxxxxx wrote:
          Hi Shawni
          I want create layer in the Layer Browser (and assign to object (later))
          My code
          > Bool AC4DPOLY::CreateLayer     (BaseDocument \*mydoc, String LayNameString) \> { \>      GeListHead \*layerlist = NULL; \>      layerlist = mydoc->GetLayerObjectRoot(); \>      if(!layerlist) return FALSE; \>      Bool laycheck =TRUE; \> \>      //check current layerlist \>      LayerObject \*layer = (LayerObject\* )layerlist->GetFirst(); \>      if (layer) \>      { \>           for (layer; layer; layer = layer->GetNext()) \>           { \>                if (LayNameString == layer->GetName()) \>                { \>                     laycheck = FALSE; \>                     break; \>                } \>           } \>      } \> \>      //Create layer \>      if (laycheck) \>      { \>           //Create layer with LayNameString name; \>      } \> \>      return TRUE; \> }
          Dont know howto alloc LayerObject, not sample in SDK.
          Sorry my bad english.
          Dinnye
            On 22/07/2009 at 16:18, xxxxxxxx wrote:
            LayerObject* lo = LayerObject::Alloc();
            if (!lo) // allocation failed
            I see you tried doc->InsertObject(). You probably need to get the layer root (doc->GetLayerObjectRoot()) and append to the list (GeListHead->InsertLast(lo)).
            Set an object to the layer using obj->SetLayerObject(lo).
            Use lo->GetLayerData(doc,...) to get the layer settings.
            About all that I can tell you about layers. 😄
              On 23/07/2009 at 01:12, xxxxxxxx wrote:
              Thanks. Try this.
                On 23/07/2009 at 02:05, xxxxxxxx wrote:
                Yes, you have to insert the layer into the layer's list.
                Simple example, inserts a layer:
                > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      LayerObject \*layer = NULL; \>      layer = LayerObject::Alloc(); \>      if (!layer) return FALSE; \> \>      GeListHead \*layerlist = NULL; \>      layerlist = doc->GetLayerObjectRoot(); \>      if (!layerlist) return FALSE; \> \>      layerlist->Insert(layer, NULL, NULL); \> \>      layerlist->Message(MSG_UPDATE); \> \>      EventAdd(); \> \>      return TRUE; \> } \>
                  On 23/07/2009 at 03:26, xxxxxxxx wrote:
                  wow, cool!
                  Thanks Matthias.
