draw dotted lines
On 20/07/2009 at 04:47, xxxxxxxx wrote:
Cinema 4D Version: R9.6-R11
Language(s) : C++ ;---------
Hi.quick question:
how can i draw dotted lines in my tool plugin?code from this thread doesnt work for me :
linkit suggested using negative values for transparency.
greetings,
Daniel -
On 20/07/2009 at 08:07, xxxxxxxx wrote:
Dan had to create his own 'dotted line' drawing routine (probably using one of the line routines like Line2D, LineCS, LineStrip...). There is no built-in support to do it. Maybe he'll show up here and provide code.
On 20/07/2009 at 08:09, xxxxxxxx wrote:
It appears that void SetTransparency(LONG trans) with a positive parameter draws a dotted line and negative values draw true transparencies.
My test code:
\> LONG EdgeCutTool::Draw(BaseDocument \*doc, BaseContainer &data;, BaseDraw \*bd, BaseDrawHelp \*bh, BaseThread \*bt,LONG flags) \> { \> if (!(flags & DRAWFLAGS_HIGHLIGHT)) \> return FALSE; \> \> bd->SetPen(Vector(1.f,0.f,0.f)); \> \> bd->SetTransparency(-220); \> bd->Line3D(Vector(0.f),Vector(100.f,100.f,100.f)); \> \> bd->SetTransparency(0); \> bd->Line3D(Vector(0.f),Vector(100.f,100.f,-100.f)); \> \> bd->SetTransparency(100); \> bd->Line3D(Vector(0.f),Vector(-100.f,100.f,-100.f)); \> \> bd->SetTransparency(255); \> bd->Line3D(Vector(0.f),Vector(-100.f,100.f,100.f)); \> \> return DRAW_HANDLES|DRAW_AXIS; \> } \>cheers,
Matthias -
On 20/07/2009 at 08:30, xxxxxxxx wrote:
> * * *yes indeed, thanks for that.
must have done sth wrong with the code from the original thread..I think the fake transparent look is just what i wanted!
greetings,
Daniel -
On 20/07/2009 at 17:01, xxxxxxxx wrote:
Howdy,
Well, looks like this is another thing to add to the list for things to change in an updated SDK docs. I wish I would've tried 255 for the transparency back then. :o(
Adios,
Cactus Dan -
On 28/07/2009 at 06:36, xxxxxxxx wrote:
Howdy,
> Quote: Originally posted by Matthias Bober on 20 July 2009
> ...It appears that void SetTransparency(LONG trans) with a positive
> transparencies.
> * * *Hmmmmm, I've discovered something odd about drawing in true transparency:
TransparencyIt seems that virtual geometry doesn't draw behind a transparent polygon when "true" transparency is used the the virtual geometry is selected. Is this a bug?
Adios,
Cactus Dan
