    cant convert object plugin to poly
    4 Posts 0 Posters 346 Views
      On 10/07/2009 at 14:44, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      i have one object plugin that cant be converted to polygon. any ideas what could cause this behaviour? i have no clue, since it is based on another plugin, which could be converted..
      thanks for all input..
      ello
        On 10/07/2009 at 16:39, xxxxxxxx wrote:
        Does it 'generate' polygon objects?
          On 11/07/2009 at 02:09, xxxxxxxx wrote:
          depends on what the child is. i clone the object with this:
          \>  BaseObject* clone = static_cast<BaseObject*>(child->GetClone(0, NULL));
          edit:
          found out that if i dont use this:
          \>  cloneOfBase = main->GetAndCheckHierarchyClone(hh,baseMesh,HCLONE_ASPOLY,&dirty;,NULL,FALSE);
          \>  if (!cloneOfBase) goto Error;
          \>  pobj= ToPoint(cloneOfBase);
          but this:
          \>  if (baseMesh->GetDeformCache())
          \>  pobj = ToPoint(baseMesh->GetDeformCache());
          \>  else
          \>  pobj= ToPoint(baseMesh->GetCache());
          than it works...
          any ideas?
            On 11/07/2009 at 03:45, xxxxxxxx wrote:
            additional info.. i need to have the part with GetAndCheckHierarchyClone to be able to use nonpolygonized objects with deformers.. or is there another way to do it?
            ello
