    still question about object axis
    4 Posts 0 Posters 465 Views
      On 14/06/2009 at 13:55, xxxxxxxx wrote:
      Cinema 4D Version:
      hi there,
      i am totally struggling now.. i need to set the axis of an object to a specific value and i have absolutely no clue how to do this. not even a shade of knowledge...
      for example i want to set it to the global (0,0,0) coordinate..
      maybe someone can help me solve this? i've got the first tip here, but i must admit that i dont understand that matrix stuff good enough to use it...
      thanks in advance,
      ello
        On 14/06/2009 at 15:29, xxxxxxxx wrote:
        could it really be that it is that simple???
        \>  void setAxis(BaseDocument *doc, BaseObject *op, Vector pos)
        \>       Matrix m;
        \>       Matrix tm;
        \>       m.off = pos;
        \>       while(op)
        \>            if (op->GetType()==Opolygon)
        \>                 tm = op->GetMl();
        \>                 PointObject *pobj = static_cast<PointObject*>(op);
        \>                 Vector *parr = pobj->GetPointW();
        \>                 LONG pcnt = pobj->GetPointCount();
        \>                 GePrint(LongToString(pcnt));
        \>                 for(int i=0;i<pcnt;i++)
        \>                      parr[i]*=tm;
        \>                 op->SetMl(m,FALSE);
        \>            setAxis(doc,op->GetDown(),pos);
        \>            op = op->GetNext();
        in my first tests it seems that this is it??
        thanks for checking,
        ello
          On 14/06/2009 at 15:55, xxxxxxxx wrote:
          hm, now i face another problem.. what is wrong with my code? i am trying to calculate the center of a polygonobject, but it doesnt work:
          \>                 Vector cpos = Vector(0);
          \>                 if (pcnt>0)
          \>                           cpos += parr[i];
          \>                      cpos /= pcnt;
          where's my fault?
          thanks and cheers,
          ello
            On 15/06/2009 at 13:44, xxxxxxxx wrote:
            hmm, somehow the axis is not centered correctly, nearby, but not exactly where it should be..
            \>  void setAxisSingleObject(BaseObject *op, Vector pos)
            \>       Matrix m;
            \>       m.off = -pos;
            \>                 parr[i]*=m;
            \>            m.off = pos;
            \>  void centerAxis(BaseObject *op)
            \>                 if (pcnt>0)
            \>                           cpos += parr[i];
            \>                      cpos /= pcnt;
            \>                      setAxisSingleObject(op, cpos+op->GetPos());
            anyone sees where i am wrong here?
            thanks in advance.
            ello
