    Issue setting rotation
    5 Posts 0 Posters 556 Views
      On 12/06/2009 at 16:03, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      All of a sudden i cant set the angle properly:
      \>                                     GeData data;
      \>                                     obj->GetParameter(DescID(ID_BASEOBJECT_SCALE), data, 0L);
      \>                                     obj->SetParameter(DescID(ID_BASEOBJECT_SCALE), GeData(data.GetVector()*_resize), 0L);
      \>                                     obj->SetParameter(DescID(ID_BASEOBJECT_ROTATION), GeData(Vector(45,0,-45)), 0L);
      but the result in cinema is
      2578.31 °
      0
      -2578.31 °
      Whats that ?? I guess i just didnt notice that i am doing something wrong because i did a random plugin and thus didnt check the values as it looked ok to me...
      is there a solution somewhere? why cant i set the same values via script that i can set inside cinema via the gui??
      thanks for your help,
      ello
      thanks for your patience 🙂
      ello
        On 12/06/2009 at 16:50, xxxxxxxx wrote:
        Simple: All rotations are in Radians, not degrees.
        I use these inline converters when the angles are variable:
        inline Real ToRad(Real r) { return ((r)*0.017453292519943295769236907684886f); }
        inline Real ToDeg(Real r) { return ((r)*57.295779513082320876798154814105f); }
          On 13/06/2009 at 00:55, xxxxxxxx wrote:
          thank you very much, it works but wow, where do those numbers come from?
            On 13/06/2009 at 10:39, xxxxxxxx wrote:
            PI/180 and 180/PI. Instead of doing the floating point math over and over (even inline), I simply put in constants. More precision than ever needed and beyond that of a 32-bit IEEE floating point encoding but I simply copy-pasted the values from the Windows Calculator. 🙂
              On 13/06/2009 at 13:29, xxxxxxxx wrote:
              it works totally cool.
              i must generally thank you and all others here in this forum for all the help i find here. i hope someday i can return something
              ello
