    AtomArray to BaseObject
    2 Posts 0 Posters 229 Views
      On 12/06/2009 at 12:53, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi there,
      i have managed to create an AtomArray which holds all objects in the scene, now i want filter away the the lights out, create a new Document and copy the Objects from the list to that new doc.
      \>  sceneObjects->FilterObject(Olight,NULL,FALSE);
      \>  BaseDocument *doc3 = BaseDocument::Alloc();
      \>  if (!doc3) goto Ende;
      \>  BaseObject *newParent = BaseObject::Alloc(Onull);
      \>  newParent->SetName(objName);
      \>  doc3->InsertObject(newParent,NULL,NULL,FALSE);
      \>  for(int i=0;i<sceneObjects->GetCount();i++)
      \>  doc3->InsertObject(static_cast<BaseObject*>(sceneObjects->GetIndex(i)),newParent,NULL,TRUE);
      anyway, the line in the loop where i try to insert the objects simply switches cinema away, not even a crash message appears 🙂
      what am i doing wrong there? i guess something very basic?
      thanks,
      Ello
        On 12/06/2009 at 13:16, xxxxxxxx wrote:
        ok, i managed it to work , at least somehow:
        > <code>
        >> <code>
        >>> <code>
        \>  oc3->InsertObject(static_cast<BaseObject*>(sceneObjects->GetIndex(i)->GetClone(0L,NULL)),newParent,NULL,TRUE);
        >>> </code>
        >> </code>
        > </code>
        but now if the base document looks for example like this:
        parent
        -object1
        -object2
        the target looks like this:
        newParent
        -object1
        -object2
        -parent
        --object1
        --object2
        something still wents wrong and now i really dont have a clue what it is??
        anyone has a hint?
        and to make it more strange the light objects are still there. seems the Filter doesnt work...
        edit: i guess its better to filter manually by using GetType(), but why are those duplications happening? ok, i think because the parent gets copied with the childs?? gonna test 🙂
        thanks,
        ello
