    Usign RealToString function
    3 Posts 0 Posters 310 Views
      On 11/06/2009 at 01:59, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      Platform:    Mac  ;
      Hi all
      I'm very new to COFFEE although I've been using C4d for quite a while. Now I'm writing some scripts to aid me with some mundane tasks.
      I've got this piece of code that should add a number to a name and I'm stuck and seriously ashamed that I can't get it to work.
      This is the code, the console says Variable or function expected where the RealToString function is...
      for(i=SelectedCounter-1;i>=0;i--)
      doc->AddUndo(UNDO_OBJECT, SplinesArray _);
      Extrudes _#ID_BASELIST_NAME = SplinesArray _#ID_BASELIST_NAME + RealToString(i); // names the extrudeNurbs
      SplinesArray _- >Remove();// removes object
      SplinesArray _- >InsertUnder(Extrudes _);//places it under ExtrudeNurbs
      Extrudes _#EXTRUDEOBJECT_MOVE:VECTOR_Y = -1* SplinesArray _#ID_BASEOBJECT_POSITION:VECTOR_Y; //extrudes downwards
      Extrudes _#EXTRUDEOBJECT_MOVE:VECTOR_Z = 0; // zeros the Z extrusion
      Let me know if you can figure out what I'm doing wrong.
        On 11/06/2009 at 06:58, xxxxxxxx wrote:
        In COFFEE, you use tostring() to convert a variable of any type to a string.
        > SplinesArray#ID_BASELIST_NAME + tostring(i);
          On 11/06/2009 at 07:12, xxxxxxxx wrote:
          Thank you very much
