    CallCommand(12144); [Group] doesnt work
    6 Posts 0 Posters 600 Views
      On 09/06/2009 at 14:24, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi there,
      i have read thru the different threads here concerning joining objects. but dont get it to work.
      what i am doing is loading a document :
      BaseDocument* doc2 = LoadDocument(fileName,0L, NULL);
      and after selecting some objects via
      doc- >SetActiveObject(child, SELECTION_ADD);
      i want to connect them with
      CallCommand(12144);
      i also tried to use SendModelingCommand MCOMMAND_JOIN, but that needs to have a group of subobjects, too, which i dont have in my base scene and CallCommand(100004772); doesnt work, too. the objects remain ungrouped.
      any ideas, hints??
      thanks and cheers,
      Ello
        On 12/06/2009 at 01:31, xxxxxxxx wrote:
        anyone? i still had no success with this. must be something general i guess, but i just have no idea where to look
        ello
          On 12/06/2009 at 15:47, xxxxxxxx wrote:
          I did further tests but still cant get it.
          this should connect all objects in the document (at least from my understanding) but doesnt work:
          > <code>
                                             CallCommand(100004748);
          \>  CallCommand(100004766);
          \>  CallCommand(12144);
          > </code>
          and this should create a group from all objects:
          > <code>
          \>  CallCommand(100004748);
          \>  CallCommand(100004772);
          > </code>
          anyone??
            On 13/06/2009 at 03:06, xxxxxxxx wrote:
            ok, i found out that i first had to ensure that the document was active. now i group all objects, select the parent and CallCommand(12144), but all i get is a polygonobject with no polygons??
            anyone have an idea what could cause this?
            thanks in advance,
            ello
              On 13/06/2009 at 05:09, xxxxxxxx wrote:
              i did it now with SendModelingCommand MCOMMAND_JOIN, but i still like to know why CallCommand(12144) doesnt do it?
                On 15/06/2009 at 08:07, xxxxxxxx wrote:
                Connect only works with polygon objects and editable splines.
