    please help with GetRealSpline/Memoryleak
    3 Posts 0 Posters 334 Views
      On 22/05/2009 at 12:42, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi , i am using this code to get a user spline from an input field and create a clone to be able to for example read out points with "vPosition = splineObj->GetSplinePoint(ccpos, 0, NULL);"
      if(userSpline)
      splineObj = ((BaseObject* )(userSpline->GetClone(COPY_NO_BITS, NULL)))->GetRealSpline();
      everything works well, except that once again i have a memory leak. i think i have to free something, but what?? it isnt the splineObj, but i guess its something that happens when using GetRealSpline().. which i need to use, since the use should be able to use parametric splines...
      thanks for any hints,
      cheers, ello
        On 22/05/2009 at 13:28, xxxxxxxx wrote:
        The memory leak is your clone, I guess.
        You should store the pointer to the clone in a separate Variable, get the real spline from it and then free the clone after use.
        Jack
          On 22/05/2009 at 13:52, xxxxxxxx wrote:
          thank you.. got it working
