    execute Center Axis with parameters
    3 Posts 0 Posters 297 Views
      On 18/05/2009 at 03:22, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      Hi all out there ;-}
      I want to center the Axis of all objekts to there center ;-}.
      But with CallCommand(1010819); only  the Dialogbox ist opening.
      Is ther a way to set the parameters:
      with children
      all objects
      enable auto Update
      and at last run the modification?
      Thanks to your help.
      Chears Ronny
        On 25/05/2009 at 02:51, xxxxxxxx wrote:
        Unfortunatly the Axis Center command can't be executed through SendModelingCommand(). I am afraid you have to write your own axis center function.
          On 03/06/2009 at 07:35, xxxxxxxx wrote:
          > cheers,
          > Matthias
          ...which is a pain in the ass, because you can't "just" set the new axis (the routine needed to do that with is internal/private)... if you SetMl() on the object, the vertices get moved according to the new matrix, so you have to modify the vertices by the (inverse) delta of the old/new matrix as well.
