    Do shaders have a cache? / Trace changes
    4 Posts 0 Posters 439 Views
      On 24/04/2009 at 07:50, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      in my Generator object, I use textures/shaders for creating geometry. Since I use caching to speed up the performance, I do the following to check if anything in the object has changed, so the cache has to be recalculated:
      > \> Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); \> if (!dirty) return op->GetCache(hh); \>
      Is it possible to trace changes in a shader/texture (class PluginShader)? Of course, when the shader changes, my object must also be recalculated.
      Since, there is no PluginShader::CheckCache(), maybe this is possible using messages, but I don't know.
      Any tipps? Thanks in advance! 🙂
      Jack
        On 24/04/2009 at 08:27, xxxxxxxx wrote:
        (Of course, in the thread title it should write "Trace Changes", not "Trance Changes")
          On 27/04/2009 at 01:10, xxxxxxxx wrote:
          You can only check for container changes, IsDirty(DITY_DATA).
            On 27/04/2009 at 03:25, xxxxxxxx wrote:
            Ah! Nice, sometimes it's so simple 🙂
            Thank, I will try that!
            Jack
