    Get active tool
    15 Posts 0 Posters 1.6k Views
      On 07/04/2009 at 08:57, xxxxxxxx wrote:
      To set the current tool, use BaseDocument::SetAction(). That enables the tool by its ID (should work with plugin tools as well - best to test). You can't 'do' anything with the tool though. Tools aren't commands, they are tools and require user interaction thereafter.
      Not sure what you are after. 🙂
        On 07/04/2009 at 09:15, xxxxxxxx wrote:
        I just want to call a button (see CloneTool ->"Apply" or ClothTag->"Calculate"). I know that a tool is not just a button, but a tool might contain a button.
        The new Coffee SDK contains CallButton(...) which does exactly what I want to do, just in C++ 🙂
          On 07/04/2009 at 09:42, xxxxxxxx wrote:
          You might need to do it this way:
          object = FindPlugin(...);
          DescriptionCommand descCMD;
          descCMD.id = DescID(DescLevel(id,DTYPE_BUTTON,0));
          Py_RETURN_BOOL(object->Message(MSG_DESCRIPTION_COMMAND, &descCMD;));
          I'm just not sure if all of the possibilities in the FindPlugin() part will result in valid 'plugin' ids that result in a BasePlugin* being returned.
            On 08/04/2009 at 03:44, xxxxxxxx wrote:
            hi, doesn't work either. Hmm..
              On 08/04/2009 at 04:24, xxxxxxxx wrote:
              This seems to work. I used the CreatePolygon tool to test.
              > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      LONG tool_id = doc->GetAction(); \> \>      BasePlugin \*tool = NULL; \>      tool = FindPlugin(tool_id, C4DPL_TOOL); \> \>      if(!tool) return FALSE; \> \>      DescriptionCommand dc; \>      dc.id = DescID(MDATA_CREATEPOLYGON_BUTTON); \>      tool->Message(MSG_DESCRIPTION_COMMAND, &dc;); \> \>      EventAdd(); \> \>      return TRUE; \> } \>
                On 08/04/2009 at 06:40, xxxxxxxx wrote:
                This works fine here, too. In my case its the Apply Button of the Clone Tool. But I will check that again and I will tell you what I did wrong.
                Shawni
                  On 13/04/2009 at 08:49, xxxxxxxx wrote:
                  Hi, I guess I've the correct IDs.
                  > \>      CallCommand(450000042); \>      LONG tool_id = doc->GetAction(); // select the Clone tool \> \>      BasePlugin \*tool = NULL; \>      tool = FindPlugin(tool_id, C4DPL_TOOL); \> \>      if(!tool) return FALSE; \> \>      DescriptionCommand dc; \>      dc.id = DescID(MDATA_APPLY); \>      tool->Message(MSG_DESCRIPTION_COMMAND, &dc;); \> \>      EventAdd(); \>
                  Any suggestions? Thanks.
                    On 14/04/2009 at 03:00, xxxxxxxx wrote:
                    It seems that the DescriptionToolData Apply, New Transform and Reset Values buttons are triggered differently. I have asked the developers how the CallButton() command is working internally.
                      On 20/04/2009 at 04:08, xxxxxxxx wrote:
                      heyho, any news?
                        On 21/04/2009 at 01:05, xxxxxxxx wrote:
                        Quote: Originally posted by Shawni on 20 April 2009
                        > heyho, any news?
                        Sorry, not yet.
                          On 28/04/2009 at 01:20, xxxxxxxx wrote:
                          Hope it's not too late, anyways here is the working code.
                          > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      LONG tool_id = doc->GetAction(); \> \>      BasePlugin \*tool = NULL; \>      tool = FindPlugin(tool_id, C4DPL_TOOL); \>      if (!tool) return FALSE; \> \>      BaseContainer msg(BFM_ACTION); \>      msg.SetLong(BFM_ACTION_ID, 1440); \>      msg.SetLong(BFM_ACTION_VALUE, TRUE); \> \>      DescriptionCommand dc; \>      dc.id = DescID(DescLevel(MDATA_APPLY, DTYPE_BUTTON, tool->GetType())); \> \>      DescriptionCheckUpdate du; \>      du.doc = doc; \>      du.descid = &dc.id; \>      du.drawflags = 0; \> \>      tool->Message(MSG_DESCRIPTION_COMMAND, (void\* )&dc;); \>      tool->Message(MSG_DESCRIPTION_CHECKUPDATE, (void\* )&du;); \>      tool->Message(MSG_DESCRIPTION_USERINTERACTION_END); \>      tool->Message(MSG_TOOL_RESTART); \> \>      EventAdd(); \> \>      return TRUE; \> } \>
                          As you can see you have too send some more messages to make it work. This should work with every button. It's almost identically with internal code for CallButton().
                            On 28/04/2009 at 02:10, xxxxxxxx wrote:
                            hey Matthias, wow, thank you! Works fine.
