    load object -> loss of instance link
    5 Posts 0 Posters 526 Views
      On 25/03/2009 at 09:59, xxxxxxxx wrote:
      Cinema 4D Version:   9.6+
      i made a preset browser that is able to load objects from c4d files and insert them into the current scene.
      i have a preset-scene that contains a null object, which consist of a cube and some instances of the cube.
      when i load this null into my sceen, via the preset browser, the reference link in teh instances is lost, instead of pointing to the cube..
      when i merge the scene by hand via c4d's file menu, the instances keep their reference link to the cube, so it must be sth in my function..
      here's the code snippet:
      > \> .. \> if(!node->file.CheckSuffix("c4d")) return FALSE;                          \> AutoAlloc<BaseDocument> f_doc = LoadDocument(node->file,SCENEFILTER_OBJECTS,NULL); \> if(!f_doc){ return FALSE; } \> // get first obj in the scene. preset scenes always contain 1 obj only. \> AutoAlloc<BaseObject> op = f_doc->GetFirstObject(); \> \> // remember active object \> BaseObject\* active = GetActiveDocument()->GetActiveObject(); \> \> // make a clone of the obj and insert it into the scene \> BaseObject\* clone = (BaseObject\* )op->GetClone(COPY_NO_ANIMATION,NULL); \> if(clone)GetActiveDocument()->InsertObject(clone,NULL,NULL); \> \> // restore active object \> if(active!=NULL) GetActiveDocument()->SetActiveObject(active); \> \> // notify the scene \> EventAdd(); \> .. \>
      does somebody know what may be wrong ?
      thanks,
      Daniel
        On 25/03/2009 at 11:41, xxxxxxxx wrote:
        I guess the link is lost when creating the clone.
        You will have to use the AliasTrans class, which takes care of that, if I'm not mistaken.
        Greetings,
        Jack
          On 25/03/2009 at 13:06, xxxxxxxx wrote:
          yeah i guessing so too, but wasnt aware of the AliasTrans class. Looking at the api, it seems that's indeed the solution.
          thanks for the hint Jack!
          Daniel
            On 25/03/2009 at 13:12, xxxxxxxx wrote:
            alright just to confirm this, it worked indeed!
            thanks again.
              On 26/03/2009 at 01:16, xxxxxxxx wrote:
              You're welcome 😉
              Greetings,
              Jack
